Author Topic: Connecting a 49 way joystick ....  (Read 3036 times)
HAL-9OOO
  • Newbie
  • Last login:October 25, 2002, 04:23:58 pm
« on: October 25, 2002, 04:26:46 pm »
Somebody know how is possible to connect a Williams 49 way analog joystick to my computer ??
johnpurs
  • Last login:April 26, 2022, 10:59:30 pm
    • John &ampamp; Mad's MAME2000 Cabinet
Re:Connecting a 49 way joystick ....
« Reply #1 on: October 25, 2002, 06:08:20 pm »
It is optical not analog which makes it a lot harder to attach to a PC. There is info about what would have to be donein the joystick section of this site. I think this would be a good project for Ultimarc to tackle. As far as I know it's one of the only joysticks that have not been interfaced to the PC for MAME. I hope someone tackles this someday. I would but I seriously lack the programming skills that would be required.
MAME2K
Pins:Devil'sDare*Taxi*Meteor*Fireball 2*WC Soccer 94*WhiteWater*Catacomb*FunHouse*Nine Ball*Space Shuttle*Flight2000**SeaWitch*Centaur*Paragon*Big Game*F-14 Tomcat*
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #2 on: October 25, 2002, 06:35:06 pm »
Probably ain;t going to happen anytime soon.
http://epg3.tripod.com/sinistar.html
There's the pinouts:)
One of two things are going to have to happen.  either the 49way get's translated into an analog joystick or a custom interface and driver are made.
spidermonkey
  • Last login:October 01, 2023, 04:15:59 am
  • Bombjack junkie
« Reply #3 on: October 25, 2002, 06:57:09 pm »
Currently there is no known way to interface a 49-way stick to a pc. Buy a Happ analog stick with an ultimate handle,scrap the 5k pot switches and replace them with 100k pots and walah theres your "Sinastick" You can use a 15 pin serial/gameport cable to connect it to your pc. I know that only three of the 15 wires will be used but I can't remember which wires go to which pot. One of the electronics gurus on this board should be able to help you with that. Be prepared to spend about $110.00 for the stick and about $25.00 a pop for the 100k pot switches (2 of them) :o It all depends on how bad you want to play Sinistar,Foodfight,Roadrunner ect... with the correct controls. 2nd option Hack a pc analog flight stick.
Good luck :)
"Sinistar has bad breath"
brandon
  • Last login:December 26, 2025, 08:29:45 pm
  • I <3 arcade games.
« Reply #4 on: October 25, 2002, 08:41:56 pm »
actually I already saw I circuit for interfacing 49-ways it kinda looked like an DA converter with a resistor array...I dont know if anybody ever built one, but I have seen the schematic... I will try to find it again and post it.
SirPoonga
  • Puck'em Up
« Reply #5 on: October 25, 2002, 08:57:09 pm »
To make a 49way look like an analog to the computer you need to find a way to simulate the pot resitance at 49 7 locations on each axis the 49way detects.
Dave_K.
  • Last login:July 06, 2022, 03:27:30 pm
    • Arcade Fever
« Reply #6 on: October 25, 2002, 11:16:20 pm »
Here is the schematic for getting the 49-way to emulate a hall effect stick.  I wired up the circuit on a bread board and it works.
http://www.arcadecollecting.com/info/49way_to_Hall.gif
I'm attempting to interface this with a ps2 dual shock (still working out the kinks).  Should be do'able to hook to other analog sticks for a PC.
SirPoonga
  • Puck'em Up
« Reply #7 on: October 25, 2002, 11:43:32 pm »
that shows the hall effect as the input????
Dave_K.
    • Arcade Fever
« Reply #8 on: October 28, 2002, 12:05:50 am »
Input as in the game/pcb input.  I believe Tim made this circuit to originally replace a Sinistar stick.
