Author Topic: Multi-region DVD player output question  (Read 1673 times)
mcdo15
  • Last login:February 16, 2008, 01:49:17 pm
  • why can't i make up my mind
« on: February 17, 2005, 02:11:09 pm »
quick question...
if i import a pal dvd ....
and brought a multi-region dvd player...
hook it up to a NTSC TV...
what would be my reuslt?
will it convert the signal to NTSC?  if so which player do you recomend..
i see there are expensive converters out there but that would to seem like  a pain and be costly..
thanks in advanced  ;)
Re: Multi-region DVD player output question
« Reply #1 on: February 18, 2005, 09:38:19 am »
It would not, region encoding has nothing at all to do with video format.
Hoagie_one
  • Um....whats a cabinet
« Reply #2 on: February 18, 2005, 10:39:02 am »
my dvd player plays Pal and NTSC as if they were both NTSC.
Its still region 1 only though.
MnMCaputo
  • Last login:January 10, 2014, 05:31:40 pm
  • Built original Monster Arcade
« Reply #3 on: February 18, 2005, 12:29:21 pm »
The is a program you can use to convert the PAL to NTSC, you'd have to rip the PAL movie to your harddrive, then use TMPGEnc and convert it, and then burn a new dvd.  goto dvdrhelp.com they have it step by step there, if not doom9.net will have it
Built Monster Arcade, Steampunk MP3 touchscreen jukebox, NES itx conversion
mcdo15
« Reply #4 on: February 18, 2005, 12:55:30 pm »
im confused...how does it play pal when its another region?
i know about ripping and converting..trying to avoid that
« Reply #5 on: February 18, 2005, 01:32:11 pm »
Once more... regions are not related to formats.  They are simply coincedental.
Samstag
  • Last login:December 16, 2016, 01:41:19 am
  • That's not a llama!
« Reply #6 on: February 18, 2005, 01:34:33 pm »
My DVD player plays PAL and NTSC fine.
mcdo15
« Reply #7 on: February 18, 2005, 03:19:29 pm »
Chadtower : sorry since im a noob at this....
since i thought pal was a different region and encoded differnetly..it was meant to be display on a pal type tv.  aparently that is false.
thank you all for your feedback.
SeaMonkey
  • Last login:March 21, 2014, 02:57:17 pm
  • "Wizard has shot the food! Ehrrummiehrrr"
    • Ultimate Battles!
« Reply #8 on: February 18, 2005, 03:28:34 pm »
I have one of these. They are on ebay all the time and it plays PAL and NTSC perfectly. It has a built-in converter and it is region free.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=50599&item=5752816854&rd=1&tc=photo
« Reply #9 on: February 18, 2005, 03:30:56 pm »
PAL is a format, it is not a region.  Region encoding means that they put a flag on the disc telling the player what part of the world it is for, and the player can play it or not.  A format is the actual video encoding.
Grasshopper
« Reply #10 on: February 18, 2005, 03:55:21 pm »
I believe that most modern TVs will accept PAL and NTSC signals.
I have a variety of Dreamcast games, some PAL and some NTSC, and they all work on my TV.
