Author Topic: Pushbuttons momentary  (Read 1106 times)
Marky_1979
  • Last login:January 03, 2017, 11:07:07 am
    • Personal Webspace
« on: February 14, 2005, 04:41:32 am »
Do i wire up momentary pushbuttons the same as normal pushbuttons there the ones marked B.
Samstag
  • Last login:December 16, 2016, 01:41:19 am
  • That's not a llama!
Re: Pushbuttons momentary
« Reply #1 on: February 14, 2005, 06:45:58 am »
I don't know what "normal" pushbuttons are, but you really can't hook up those switches wrong.  They only have two terminals, and you should only have two wires.  So hook ground/common to one side and whatever you're controlling to the other side.  You don't have to worry about polarity.
danny_galaga
  • Last login:Today at 12:57:58 am
    • dans cocktail lounge
« Reply #2 on: February 14, 2005, 06:55:31 am »
if by normal pushbutton you mean arcade pushbuttons then yes wire the same. arcade pushbuttons are momentary on
