Author Topic: Quick answer - size for holes  (Read 1167 times)
cholin
  • Last login:July 16, 2009, 09:22:25 pm
    • Nilok Productions
« on: February 12, 2005, 09:10:35 pm »
I realize you should use 1-1/8 bit, but instead of buying one, can I use 1-1/4?  its like 1/8 inch difference, shouldnt cause any problems...does anyone know?
SirPeale
  • Green Mountain Man
Re: Quick answer - size for holes
« Reply #1 on: February 12, 2005, 09:17:52 pm »
Yes, it's too big.  Don't do it.
IMMark
  • Last login:August 05, 2016, 07:30:02 pm
« Reply #2 on: February 13, 2005, 11:40:57 am »
I agree...don't do it
You can get a 1 1/8" spade bit, very inexpensive, or a entire set for $5.
When you use them, drill from both sides to prevent blowout.
Drill from front until, the point breaks through, then finish from the back side.  A hole saw gives a better cut, and is more expensive.  But if you use a spade from both sides, results are more than addequate. :)
cholin
    • Nilok Productions
« Reply #3 on: February 13, 2005, 12:16:04 pm »
Alrighty Ill look for a spade bit.
