Author Topic: Slow booting Dreamcast backups...  (Read 5824 times)
RitchieTheBrit
  • Last login:September 29, 2015, 12:03:36 pm
    • The Urban Dead Survivor Diaries
« on: February 12, 2005, 01:24:21 pm »
Can any of you guys help me?  I recently managed to get ahold of an iso of Headhunter Disc 1 to replace my knackered original with (excellent game, but it's getting hard to get ahold of now!), and although it works fine after it's burned, it seems to take a long time to recognise the disk.
The motor whirrs for almost a minute while the laser tracks the 1st_read.bin, I think, and I really dont want a knackered motor!  Has anyone else had this problem, or does anyone know what the problem is?
I've never had it with an Emulator disc, and a booting from the Utopia disk doesnt help!
Any help is appreciated, guys!  For the record the disc is a ritek 48x.  The image is CloneCD format, and I'm burning at 2x, in data mode.
Well I say let's get out there and TW*T it!
One good knee in the happy-sacks and it'll go down like any other smegger!
pointdablame
Re: Slow booting Dreamcast backups...
« Reply #1 on: February 12, 2005, 01:25:55 pm »
the data for the disc is probably to close to the center of the disc.  Create a dummy file so that the real game data is on the outermost rings of the cd.
first off your and idiot
RitchieTheBrit
« Reply #2 on: February 12, 2005, 01:29:58 pm »
Nope, the file fills the disc!  That was my first thought, although the sound of the GD-Rom gave me the impression that was the problem!
pointdablame
« Reply #3 on: February 12, 2005, 01:37:00 pm »
well then.......
My only other idea is to try another DC if you can to see if it might be your laser.  Or eBay.
RitchieTheBrit
« Reply #4 on: February 12, 2005, 02:11:40 pm »
Nope, I've got two DC's one mine and the other is my GF's same on both, except one makes a little less noise than the other, it still takes the same time!
« Last Edit: February 12, 2005, 02:52:18 pm by RitchitTheBrit »
SOAPboy
  • Last login:August 01, 2009, 03:36:12 am
  • ..::GeeK::..
« Reply #5 on: February 12, 2005, 10:58:14 pm »
Different Media..
Grasshopper
  • Last login:March 04, 2025, 07:13:36 pm
« Reply #6 on: February 13, 2005, 09:08:16 am »
I've noticed with many PC CD drives that if the disk is slightly damaged but still readable then the drive makes a a loud whirring noise when reading data.
Also, I've read that PC drives automatically slow down if they're having trouble reading a disk. Perhaps the DC does the same thing.
I would suggest making a backup of your backup using a high quality blank disk and see if that solves the problem.
RitchieTheBrit
« Reply #7 on: February 13, 2005, 01:15:26 pm »
Tried all of the above!
« Last Edit: February 13, 2005, 05:03:30 pm by RitchitTheBrit »
Arcadiac
  • Last login:April 14, 2020, 01:26:31 am
« Reply #8 on: February 13, 2005, 05:56:25 pm »
RichitThe Brit-----"*!!! - EDIT - PROBLEM SOLVED!!!* "
Ok, so please share the solution as someone else may be able to use it.   ;D
Thanks! ARCADIAC!
RitchieTheBrit
« Reply #9 on: February 23, 2005, 02:00:22 pm »
Thanks! ARCADIAC!
Sorry dude, I thought the post had failed!
pointdablame
« Reply #10 on: February 23, 2005, 06:23:49 pm »
use NERO and mess with your overburning settings... you should be able to fit it on a disc
RitchieTheBrit
« Reply #11 on: February 24, 2005, 04:53:36 pm »
Okay point, I think thats about the only option I havent tried!  I'll let you know if it works!
DrewKaree
  • HAH! Nice one!
    • A lifelong project
« Reply #12 on: March 05, 2005, 03:12:42 pm »
Just came across an interesting article regarding Ritek.
Seems Ritek has been recommended by several folks, and the reason given is that they're easier to get.  Now, obviously, everyone's actual experience will color their opinions, but since I've just gotten a burner, I decided to do some reading on what would be an "ideal" disc to purchase, so as to lessen the chance for coasters.  Those dual-layer discs I bought a THREE pack of are friggen expensive, and the spindles/10 packs etc of DVD-R's are cheaper, but still a touch expensive to be making coasters.
Check out the article here:
www.afterdawn.com/ritek_dvd-r_quality.cfm
I've found Taiyo Yuden's on NewEgg fairly cheap, and someone posted a site on several methods to determine who the manufacturer of the DISC (not the brand name on the package, i.e. Maxell, Verbatim, Fujifilm, etc) is.  While not foolproof, I've bout 5 packages of discs so far, and the methods have been spot on for the manufacturer I was looking for.
I'm really just posting this for the article mentioned above, as several folks have posted with problems while using Ritek's, and perhaps that article explains it a bit for 'em.
*shrug*
shamelessly stolen from rampy
RitchieTheBrit
« Reply #13 on: March 05, 2005, 06:08:46 pm »
I'm fully aware of the fog surrounding the different medias, but to clarify, Ritek as a company began by producing the dye used for recordable media, and a very high quality dye at that.
« Last Edit: March 05, 2005, 07:35:44 pm by RitchitTheBrit »
DrewKaree
  • HAH! Nice one!
« Reply #14 on: March 05, 2005, 07:18:18 pm »
The article is referring to the Ritek discs.
Since you were asking for help and your efforts thus far haven't worked, I figured I'd just offer that up as a potential issue.  Hopefully it might help others.
Good day sir.
*edit*
kept the "good day sir", since you liked it  ;) and appreciate your further comments.
Consider us re-started  ;D
« Last Edit: March 05, 2005, 09:33:28 pm by DrewKaree »
RitchieTheBrit
« Reply #15 on: March 05, 2005, 07:33:03 pm »
Hey, sorry to offend dude, I have a rather sarcastic sense of humour!  No offence meant.  :-\
It just seemed a little unrelated to the topic, that was all!
As for the CloneCD saga that I have been experiencing, it is not really down to Clone, as Nero throws a wobbler as well!  All I can think is that I'll need to pick up some 99min discs and try one of them!
God alone knows!
Tell ya what, lets start again...
BTW, love the Dickension 'Good day, sir!', don't think I've ever been called sir!   ;D
