Author Topic: ArcadeVGA M.A.M.E. Resolution Tool: Need help  (Read 1361 times)
vibez
  • Last login:February 09, 2011, 08:33:20 am
« on: February 12, 2005, 03:47:57 am »
High guys. I thought I had this running ok. But I dont think mame is picking up the custom resolutions for each game. For instance, I have an aracadecga running on a 15hz arcade monitor. Simpsons bowling runs in a square approx 50% the size of my screen.
How can I make sure mame picks up the customs resoultions ini's? Do I need to add something to mame.ini? or add a commandline parameter to mamewah, the fronend i'm using?
UPDATE:
Ok I enabled HWstretch in the mame.ini & now simpsons is running fullscreen, although it does flicker a bit.
I didnt think I was supposed to use HWstrech If I was using the Resolution tool?
Can anyone explain?
« Last Edit: February 12, 2005, 04:05:49 am by vibez »
