Author Topic: Galaga88 runs, but now sound probs on pacman, galaga  (Read 1078 times)
rerstad
  • Last login:December 11, 2006, 01:25:57 pm
« on: February 10, 2005, 08:11:24 pm »
I had everything set up with Mamev89, all the classic games ran fine, except that games like Galaga88 and Pacmania had BAD frameskipping.
« Last Edit: February 11, 2005, 06:40:57 pm by rerstad »
rerstad
Re: Galaga88 runs, but now sound probs on pacman, galaga
« Reply #1 on: February 11, 2005, 06:47:26 pm »
OK, I've got to be doing something stupid that I can't figure out.  I found an old thread about sound quality, tried changing the ini as described there--no difference.
If I run buddamamev91, mamev80 or nonamemamev83--I get the same result each time--galaga88 runs fine (framerate varies in each case and is almost too slow with v91) but the sound is a bit garbled in galaga, pacman and mspacman (those are the only ones I've really tested lately).  Doesn't matter if I launch from commandline or Mamewah.
Any ideas why each version would have the same problems, when all those games played fine a few days ago????  What'd I screw up?
I'm running a PIII, 1ghz w/ 512mb ram w/XP home.
