Author Topic: Operation Wolf help  (Read 966 times)
killbill
  • Last login:November 05, 2025, 02:53:17 pm
  • When I die, I want to go to arcade heaven!
Operation Wolf help
« on: February 09, 2005, 02:36:19 pm »
Hi,
I just recently purchased an OPeration Wolf cab.  The game worked, but the coin switches would not register credits.
So, I checked continuity all the way to the jamma plug.  All was good.  So, I removed the Jamma plug from the main board and bent a few of the connectors to make better contact.
I plugged it back in and fired up the machine.  \
Good news:  Coin slots works.
Bad News: The monitor has become just blue wavy lines.
This is the point when I did something really stupid.  I started messing with all of the picture adjusting knobs in the back of the monitor.  There are about eight of them.  I messed them all up.
Later I realized that by messing with the monitor wires that were running into the jamma plug, the picture would get a little better.
So, I'm going to pick up a new Jamma connector and re wire it; but that leaves the monitor and the adjustment knobs being so far out of whack that even if the jamma plug was working great, I still wouldn't see a clear picture.
Is there any way to reset the knobs on the back of the monitor, and start from scratch to adjust the picture.  I honestly messed with it for two hours and couldn't get close.
Any info is truly appreciated.
Thanks.
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
Re: Operation Wolf help
« Reply #1 on: February 09, 2005, 06:04:07 pm »
Move them all to the half-way point. You can probably go from there....
NO MORE!!
