Author Topic: Front end recommendation - XP / ARCADEVGA/ BETSON  (Read 1046 times)
jsansoterra
  • Last login:February 15, 2005, 12:04:51 am
« on: February 08, 2005, 06:03:14 pm »
Greetings!
« Last Edit: February 08, 2005, 06:18:06 pm by jsansoterra »
Re: Front end recommendation - XP / ARCADEVGA/ BETSON
« Reply #1 on: February 08, 2005, 07:22:34 pm »
Don't think EmuLoaded does low-res, I could be wrong tho.
MAMEWAH works with both AVGA & SlikStik, you might need to do some tweaking depending on how the inputs are mapped etc...  Personally I use 368x240 for the layout, it looks great IMHO.
I'm not 100% sure which other FE's support the AVGA, so I'll leave it up to the other devs :)
youki
  • Last login:October 12, 2025, 12:33:39 pm
  • Atomic Front End Creator
    • Atomic Front End
« Reply #2 on: February 09, 2005, 04:05:58 am »
Hi,
Atomic Front End support the ArcadeVGA at 100% .
and runs on XP.
I didn't know the Slikstick.  But if it maps keyboard it should work without problems. Use the AtomicKey.Exe provided with the front end to configure it.
If it is a standard PC joystick it should too.
The web site is : http://www.atomicfe.com
Personnally i use layout in 256*256 or 640x288 .  But Atomic Front End support all ArcadeVGA resolutions. And you can use the same layout in all resolutions (strechting) and all Orientations.
It is very easy to configure.
Youki
jsansoterra
« Reply #3 on: February 09, 2005, 10:42:42 am »
Thanks for the suggestions! I'll check them out!
 :D
