Author Topic: Betson monitor and PC standby  (Read 1486 times)
jsansoterra
  • Last login:February 15, 2005, 12:04:51 am
« on: February 08, 2005, 04:28:10 pm »
I have a MAME setup using a Betson monitor and ARCADEVGA card.
When the PC goes to sleep (due to inactivity) the Betson displays a rectangular box that says 'check signal' (or some such). Obviously this is due to the PC being asleep.
Is there a way to make this BOX disappear so that it does not burn into the screen?
Right now the best I can do is turn on a 'blank' screensaver.
Thanks  :o
desmatic
  • Last login:June 25, 2006, 02:25:53 pm
    • Easy MameCab
Re: Betson monitor and PC standby
« Reply #1 on: February 08, 2005, 06:39:29 pm »
you need to modify you're power settings.  Disable turn off hard disks, and monitor, and all that jazz.  You don't want any of that stuff enabled in a cabinet.  Just use the screensaver supplied by your fe, or launch a game that has one.
jsansoterra
« Reply #2 on: February 09, 2005, 10:41:25 am »
Desmatic,
Yes, that is what I'm doing. Basically, throwing up a 'blank' screensaver at 15 minutes of no activity.
I just thought it would be nicer to have the PC actually 'sleep' when not in use, but no biggie!
Thanks again for the help.
Pac Threat
  • Last login:June 29, 2005, 04:38:56 pm
  • MAME made me do it.
« Reply #3 on: February 11, 2005, 10:16:49 am »
jsansoterra,
What is your opinion and experience for the Betson?  I assume thats the 27" one that Im on the verge of getting.  I just got my arcadevga card in the mail.
I want to head to the pittsburgh betson soon.
jsansoterra
« Reply #4 on: February 14, 2005, 11:51:00 pm »
So far, the Betson monitor has been terrific. I did all the setup tweaking with my normal 'pc' video card and then switched to the ARCADEVGA card when it was finally installed in my cabinet.
BTW: I installed it into a SlikSik cabinet and it fit great. The bezel SlikStik sent with the cabinet fit the monitor as well.
