Author Topic: Using Serial Mouse/Trackball - This thing sucks  (Read 1867 times)
daveg2000
  • Last login:January 02, 2009, 08:55:51 pm
  • PSP? Yeah right. GP2X Baby! This thing is awesome
    • www.davegrams.com
« on: February 06, 2005, 10:12:45 am »
Im in the planning stage of building a new mega-cabinet
in place of the cabinet I'm using now (which is a Defender-style cab)
I have no place for a trackball right now, so I just use a Serial
Trackball/Mouse.
I've noticed when trying to play games in Mame w/it, that I only
get movement that only goes so fast on the screen.
Meaning, if I play a game where you could normally ZIP a cursor across the screen, it only moves at a turtles pace, nomatter how fast you spin the ball....
If I go the way of ordering a ball from Happs, say with a USB connector, am I going to run into this same 'limitiation' or is there something else I need to get the true 'spin speed' out of my balls?
(that just sounds wrong)
hehe  thanks.
...so I will ask you... "Deal, or No Deal?"
Re: Using Serial Mouse/Trackball - This thing sucks
« Reply #1 on: February 06, 2005, 10:30:16 am »
Have you set the analog sensitivity in the Tab > Input menu? ;)
daveg2000
    • www.davegrams.com
« Reply #2 on: February 06, 2005, 02:03:03 pm »
Actually... I think I did try this (but it may have been loooong ago)
I'll try again later today and see if that helps any....
daveg2000
    • www.davegrams.com
« Reply #3 on: February 06, 2005, 05:19:04 pm »
OKay, I went into a good game to test in (Missile Command)
and changed the default sensitivity to 50% instead of 20%.
Yes, the cursor moves faster, with less ball spin... which I guess
is by design....
But when I spin the ball (say left to right) to get the crosshair
over on the right side... the cursor bounces around a little and
never goes across.
If I roll the ball Slower, the crosshairs respond as they should..
Could this maybe be my trackball/mouse ?   Something
with the sensors inside not being able to handle 'fast response'?
JODY
  • Last login:June 08, 2025, 11:26:01 pm
  • After a long delay...the arcade is underway!
« Reply #4 on: February 06, 2005, 05:51:24 pm »
Sounds like the sensitivity is now too high.
« Last Edit: February 06, 2005, 05:53:35 pm by JODY »
daveg2000
    • www.davegrams.com
« Reply #5 on: February 06, 2005, 08:44:23 pm »
Nah.. even when the sensitivity is down... (even at the default of 20%)
it would react the same way if I spun the ball fast...
Is this something that a good quality ball would fix?
I am not familliar with the good or bad qualities in a mouse/trackball.
JODY
« Reply #6 on: February 06, 2005, 10:11:17 pm »
Does it work fine in Windows?
daveg2000
    • www.davegrams.com
« Reply #7 on: February 10, 2005, 08:03:12 am »
yup.. mouse pointer works normal in windows....
I still think its just junk...  ;)
« Reply #8 on: February 10, 2005, 10:58:06 am »
never goes across.
This sound like what can happen when the encoder wheel is not set correctly between the optics.  Not sure why that would be the case here...
