Author Topic: Mamewah help??  (Read 2192 times)
simmonz
  • Last login:February 09, 2005, 04:23:13 am
Mamewah help??
« on: February 05, 2005, 12:46:08 am »
 :( can someone please help me i cant figure out why my joystick wont scroll the Mamewah menu i can use them in game etc and buttons select games load games just the stick wont do nothing ive scan the forums looked at examples and follow tuts and ripped my hair out plz help me!
jcrouse
  • Last login:January 09, 2010, 05:53:51 pm
    • CPViewer
Re: Mamewah help??
« Reply #1 on: February 05, 2005, 01:20:18 am »
In the ctrlr folder there is a file named default.ini. Look for the joystick parameter and change it from 0 to 1. You may also want to slow down your scrolling using the mouse_x_sensitivity and mouse_y_sensitivity. Try abour 250.
Good Luck,
John
simmonz
Re: Mamewah help??
« Reply #2 on: February 05, 2005, 01:25:24 am »
THANKS JOHN HAVE DONE THAT HERE IS MY FILE
### INPUT MAPPINGS ###
# main form
UP_1_GAME         "JOY1_UP"
DOWN_1_GAME         "JOY1_DOWN"
UP_1_PAGE         "DIK_R"
DOWN_1_PAGE         "DIK_F"                         ===(THIS WORKS ONLY)!!!!!!!!!
UP_1_LETTER         "JOY1_LEFT"
DOWN_1_LETTER         "JOY1_RIGHT"
FIND_GAME         "DIK_TAB"
RANDOM_GAME         "DIK_LSHIFT"
SELECT_EMULATOR         "DIK_Z"
NEXT_EMULATOR         "DIK_4"
PREVIOUS_EMULATOR      "DIK_6"
SELECT_GAMELIST         "DIK_X"
NEXT_GAMELIST         "DIK_3"
PREVIOUS_GAMELIST      "DIK_5"
ADD_GAME_TO_LIST      "DIK_A"
REMOVE_GAME_FROM_LIST      "DIK_S"
MENU_SHOW         "DIK_2"
MENU_LOCK         "DIK_LALT & DIK_2"
LAUNCH_GAME         "DIK_1"
LAUNCH_GAME_WITH_OPTIONS1   "DIK_LCONTROL & DIK_1"
LAUNCH_GAME_WITH_OPTIONS2   "DIK_LALT & DIK_1"
LAUNCH_APP_1         "DIK_C"
LAUNCH_APP_2
LAUNCH_APP_3
EXIT_WITH_CHOICE
EXIT_TO_WINDOWS         "DIK_ESCAPE"
EXIT_AND_RUN_APP
EXIT_AND_REBOOT
EXIT_AND_SHUTDOWN
# options form
OP_UP_1_OPTION         "DIK_UP
Minwah
    • MAMEWAH
Re: Mamewah help??
« Reply #3 on: February 05, 2005, 01:55:54 pm »
Is it a PC joystick, or arcade joystick via keyboard encoder?
simmonz
Re: Mamewah help??
« Reply #4 on: February 05, 2005, 04:09:53 pm »
its a arcade joystick from real cabnet converted and via sound card joystick port!
it registers in windows calibrate and works on games but not in mamewah menu ?????
im stumpted ???
simmonz
Re: Mamewah help??
« Reply #5 on: February 05, 2005, 08:36:49 pm »
i dont no how to map them i think also need examples or someting before i have no hair left WAH!
also pluged in my logitech usb joystick and it works perfectly... WAH!
« Last Edit: February 05, 2005, 08:38:51 pm by simmonz »
Minwah
    • MAMEWAH
Re: Mamewah help??
« Reply #6 on: February 06, 2005, 10:27:58 am »
Probably the joystick number...check in control panel for the order of the game controllers.  First in the list should be JOY1 etc...
If you only have 1 joystick plugged in I don't know tho...
Edit: if all else fails, there's always JoyToKey: http://hp.vector.co.jp/authors/VA016823/joytokey/english.html
simmonz
Re: Mamewah help??
« Reply #7 on: February 06, 2005, 11:01:00 pm »
thanks man its sorted!!!! ::)
Minwah
    • MAMEWAH
Re: Mamewah help??
« Reply #8 on: February 07, 2005, 11:47:45 am »
Config error or did you use JoyToKey?
simmonz
Re: Mamewah help??
« Reply #9 on: February 09, 2005, 04:17:53 am »
not sure but i configed it to buttons for now !
still not sure why joy not work ?
Minwah
    • MAMEWAH
Re: Mamewah help??
« Reply #10 on: February 09, 2005, 05:58:04 am »
Try it with joy1_x_analog 0 and joy1_y_analog 0 (if you haven't already).
