Author Topic: ArcadeVGA Output testing  (Read 1071 times)
nussmier
  • Last login:November 06, 2018, 08:03:23 pm
« on: January 31, 2005, 11:16:29 am »
Does anyone know a way to test the ouptut from an ArcadeVGA card with a multimeter to see if it is outputing correctly?  For example is there a test program or something that you can run that outputs a certain voltage to the Red, Green, Blue, H/V sync ouptuts on the arcadeVGA card to ensure the card is working properly.  Thanks for any help.
