Author Topic: How do I test A/R II board on a StarWars cockpit?  (Read 4211 times)
BazookaJo
  • Last login:December 20, 2022, 03:53:30 pm
    • BazookaJo Paper models
« on: January 23, 2005, 04:38:24 pm »
Total newbie to electronics but have bought a multimeter and want to test the Audio/Reg board.
Now need step by step idiot-proof instructions to try determine if there's a problem e.g. turn the machine on/off.  Set multimeter to setting (x), Connect red wire to point (a), connect black wire to point (b) look for number (y) - you get the picture.
To make this even remotely possible I have found a web site with a simplified diagram of the A/R board I/we can use for reference:
http://www.ionpool.net/arcade/cent_millipead/centipede_millipede.html#audio2
Help me ArcadeControls.com you're my only hope...
http://www.bazookajo.me.uk/ - home of the Marvin the Martian paper model :)
Re: How do I test A/R II board on a StarWars cockpit?
« Reply #1 on: January 23, 2005, 04:48:56 pm »
Where are you located?  No one is going to give you that type of instruction set.
What I can do, though, is point you to a place where you can get great, comprehensive information that will teach you everything you need.
http://slot-tech-ftp.serveftp.com:8080/techdept/general%20electronics/
Read all of that, then back up a directory and read the rest.  By the end, you will know the answers to all of your questions and a LOT more.
BazookaJo
« Reply #2 on: January 23, 2005, 06:59:18 pm »
Wow!  Looks pretty comprehensive.
May be a little advanced for me, but I'll certainly give it a go.
Cheers!
Paul.
« Reply #3 on: January 23, 2005, 10:22:09 pm »
Nah, I'm plowing through it myself.  It starts right at the beginning, for folks who don't know a thing about electronics.
