Author Topic: Wico and Pal Nuts  (Read 2129 times)
anoon
  • Last login:November 03, 2022, 09:24:53 pm
Wico and Pal Nuts
« on: October 16, 2002, 07:56:32 pm »
What is th edeal with pal nuts!?! I have been waiting for 2 months for my order to come in from Wico. I need them for my leaf switches. Are they available anywhere else?
spidermonkey
  • Last login:October 01, 2023, 04:15:59 am
  • Bombjack junkie
Re:Wico and Pal Nuts
« Reply #1 on: October 16, 2002, 11:37:48 pm »
You can get pal nuts at Home Depot , Lowes or any well stocked hardware store. Pal nuts are  a common type of fastener used on lots of different things and not just arcade push buttons. Looking at the top of a pal nut,they resemble a regular hex shaped nut but instead of a solid piece of steel they are hollow. Often reffered to as a "jamb nut" or "check nut" Probably more info than you need but I hope it helps. ;D
"Sinistar has bad breath"
anoon
« Reply #2 on: October 17, 2002, 05:42:47 pm »
Thanks for the tip!
I did do some searching online and found they had many applications. I'm heading to home depot right away!
