Author Topic: Cap Kit didn't work  (Read 1256 times)
GuinnessGuy74
  • Last login:November 08, 2011, 11:01:43 am
Cap Kit didn't work
« on: January 20, 2005, 07:50:58 pm »
Ok, I just got finished installing the cap kit for my WG K7193. Powered it up and I still have a slight wave.....looks like it is only in the corners, mostly the top!
I changed a couple of the output capacitors in my game's power supply (they were the only ones I had laying around). And it didn't help! I will have to get another power supply and test it.
I noticed the horizontal position pot on the remote is cracked and it doesn't function. When I turn it there is no movement on the screen until it hits the end and then the screen jumps to one side and then back to center when I turn the pot back. Could this be screwing up the screen? Because sometimes when I touch the remote pad the screen goes hay wire until I tap on the remote board. I just noticed this today..........any thoughts on this? Probably the cause of the whole damn problem!
Thanks for any advice/iput/suggestions/criticism..........
Jim
GuinnessGuy74
Re: Cap Kit didn't work
« Reply #1 on: January 20, 2005, 11:21:22 pm »
Tried a different power supply tonight.....no difference! Still have the wave. I also tried moving the isolation transformer further away from the tube. No change. I even added a line filter with no effect.
When I power up the monitor the wave is VERY noticeable. But after a few seconds it fades into the usual wave.
I am lost........anyone? Anyone?!
Thanks,
Jim
dabone
  • Last login:July 15, 2025, 08:32:17 pm
  • Time to work...
« Reply #2 on: January 20, 2005, 11:43:52 pm »
Do you have a frame ground attached to your monitor from the game power supply?
Later,
dabone
Ken Layton
  • Guru
  • Technician
« Reply #3 on: January 21, 2005, 01:19:21 am »
A broken pot can cause problems. Bob Roberts sells a whole kit of the pots for this board. It's on his parts page under Resistors.
GuinnessGuy74
« Reply #4 on: January 21, 2005, 04:24:45 pm »
I have the ground from the frame of the monitor going to the green wire on the 3 prong outlet. Should I tie it to the FG (earth ground) on my games power supply?
Ken, yep, next trick.....install pots from Bob!
Jim
