Author Topic: AC and DC power  (Read 1600 times)
Shape D.
  • Last login:July 05, 2012, 06:17:57 pm
  • >Look at me, I'm a Newbie<
AC and DC power
« on: January 17, 2005, 06:27:19 pm »
Anyone know how you would go about powering something off a wall outlet and a battery?
I'm looking to build a plug and play unit with the jakks units and want to make it use battery power or  use a plug to use ac power. would I just connect both? or do I have to do something more technical for it. I'm guessing the batteries wouldnt use power if theres ac goin into the unit. but I'm not really shure.
Hey Baby, Have you ever met a Newbie with 38 pages of previous posts before? Do you Want to?
SirPeale
  • Green Mountain Man
Re: AC and DC power
« Reply #1 on: January 17, 2005, 06:59:50 pm »
Get a 6v adapter.  Measure it with a multimeter first, before connecting it!  I've had a lot of adaptors, and a lot will say 7V and actually be putting out a lot more.
I cut the end off mine and soldered it to the battery leads, but I know there are other solutions.
Shape D.
Re: AC and DC power
« Reply #2 on: January 17, 2005, 07:07:53 pm »
but if I have it plugged into a wall and I have batteries in the unit will the batteries lose power while its running?
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
Re: AC and DC power
« Reply #3 on: January 17, 2005, 08:44:32 pm »
uhhh that could be dangerous if there's power running to the same leads as the batteries.
NO MORE!!
Tailgunner
Re: AC and DC power
« Reply #4 on: January 17, 2005, 11:31:11 pm »
They (whoever "they" are) make phono jacks that would work. The jack is designed with three solder tabs, one being negative (ground) with the other two being positive. One of the solder tabs connects through a set of contacts inside the plug that are normally closed, inserting the plug from the AC adapter opens them.
Your battery will connect through those internal contacts, when you plug in the AC adapter you break the normally closed connection effectively removing the battery from the circuit.
Clear as mud? ;)
LordDamo
  • Last login:December 10, 2008, 04:26:05 am
  • Damn it Jim, im a doctor not a machine . . .
    • The Kinddom of Damo
Re: AC and DC power
« Reply #5 on: January 18, 2005, 01:41:32 am »
Is the unit your building going to be like a bartop style thing? I.E. the tv and Jakk's units in the same unit? or is this more of a portible unit that you can take anywhere and plug into a tv?
Really, you dont need the batteries in one of these things. Its better to wire a transformer up to it. It will save you money (no need to buy batteries all the time) as well as the environment (not buying batteries, so you wont be throwing them away).
Religious war is like two kids fighting over who has the stronger imaginary friend . . .
Druin
  • Last login:May 10, 2009, 02:30:37 am
Re: AC and DC power
« Reply #6 on: January 18, 2005, 02:54:16 am »
Yes it's very wrong to have batteries and some other voltage source connected in parallel - just think about all those warnings about not putting normal batteries in a battery charger and that should suffice.
So to give a unit 2 options of power source, as mentioned the power sources have to be somehow switched between, whether it's a plug with switching capabilities or just an added toggle switch that routes one source at a time to the unit.
As for measuring a higher voltage on a transformer than is written on the label, that is an unregulated power supply and it will read higher when it's unloaded, but when you use it to power something, it should drop down to more around the expected level. Try putting the meter on it when it's plugged into whatever it was designed for.  Unregulated supplies are used either when the target device has a voltage regulator to stabilize it, or when the exact voltage doesn't matter.
Shape D.
Re: AC and DC power
« Reply #7 on: January 18, 2005, 11:13:33 am »
I'm planning on building a portable unit with a removable lid to keep the joysticks from being damaged, and a handle to make it easier to carry around. I haven't figured it all out yet. I just figured If I could run it off batteries when I need to the option for it would be nice.
Jabba
  • D-Hutt
  • Last login:November 16, 2020, 02:17:20 pm
  • I find your lack of faith...disturbing...
Re: AC and DC power
« Reply #8 on: January 18, 2005, 11:50:35 am »
Ummmm, wouldn't a UPS suffice? It would last for maybe an hour before the bateery dies, but wouldn't a MAME cabinet running off a battery be the same (i.e., would drain the battery quickly?)
Vids:  Home built MAME machine, Crystal Castles. Arkanoid
Pins:   Williams Aztec (working). Stern Nugent (not working...yet), Williams Phoenix (major not working, missing parts.... )
Always on the lookout for buying 90's game with Ramps that need work...
