Author Topic: Happ Perfect 360 + PS and DC guts  (Read 2096 times)
m3talslug
  • Last login:February 07, 2007, 04:22:25 pm
    • M3talslug's Control Panels
« on: October 15, 2002, 05:48:33 pm »
I'm trying to wire a Happ Perfect 360 joystick to PS and DC guts.  Could anyone give me any tips on how to use a multimeter to find the +5v on the boards?  THe only thing I Know how to do with a multimeter is check for connectivitiy.
The Happ Perfect 360 joysticks have 1ground, up, down, left, right, and +5v contacts.  I Know how to wire all but the +5v.
Please help.
toilet
  • Last login:November 11, 2005, 11:53:45 am
    • Briefcase Emulator
Re:Happ Perfect 360 + PS and DC guts
« Reply #1 on: October 15, 2002, 06:24:15 pm »
Hey metalslug,
How a friend of mine did it for PSX that's pretty safe was:
Looking at the controller's plug find the VCC +5V hole:
http://www.gamesx.com/controldata/psxcont/psxcont.htm
Jam one end of the voltimeter in that. At the other end of the PSX cable where it splits up and the wires make contact with the PCB, touch each of those contacts with the other end of the meter. When you close the circuit you found the contact for the P360.
« Last Edit: October 15, 2002, 06:25:49 pm by toilet »
m3talslug
« Reply #2 on: October 15, 2002, 09:53:58 pm »
Worked like a charm!!  Thanks a lot.
Now all I need is a schematic of the DC controller interface ;).
m3talslug
« Reply #3 on: October 17, 2002, 11:57:33 am »
Anyone know where I can find any schematics on a DC controller port?  I'm still having problems locating the +5v.  I don't want to do the trial and error method because I heard that DC controller ports burn out pretty easily if wired incorrectly.
toilet
« Reply #4 on: October 17, 2002, 02:55:44 pm »
Hey metalslug, that's cool that the PSX one worked out.
You may want to check out http://www.gamefaqs.com/console/dreamcast/game/22940.html which has some info on putting a P360 onto a DC controller.
Edit: URL changed for gamefaqs link, it's the Arcade Stick Hacking article.
« Last Edit: October 17, 2002, 09:05:24 pm by toilet »
