Author Topic: Installing T-molding How?  (Read 3461 times)
D00kie
  • Last login:October 14, 2002, 12:14:41 pm
« on: October 15, 2002, 04:44:52 pm »
I was wondering were did you get your Tmolding and how did you gut the groove to put the molding into.  I am thinking a router but have yet to find a bit that cuts a slot on the edges of the wood.  Please help!
MameFan
Re:Installing T-molding How?
« Reply #1 on: October 15, 2002, 04:47:24 pm »
1) www.t-molding.com
2) Router with correct width bit  -or- I think some have used biscut hole cutters (how you make the holes in shelving units that join with other parts with an oval shaped disc called a biscuit)
D00kie
« Reply #2 on: October 15, 2002, 04:51:31 pm »
With which type of bit though?  So far i have only found bits that round cornors of wood.
hyiu
  • Last login:August 29, 2014, 05:36:15 am
  • too many games... too little time....
    • www
« Reply #3 on: October 15, 2002, 04:56:44 pm »
if I didn't remember wrong, its called slot cutting bit (1/16 inch).... I think its mentioned here and also in some other threads where they also show link on where to buy....
http://www.arcadecontrols.org/yabbse/index.php?board=1;action=display;threadid=2572;start=0
check this link also...
http://www.coastaltool.com/cgi-bin/SoftCart.exe/a/ab/aman/slotting.htm?L+coastest+dkxv1470ff213621#cart
hope it helps....
 ;)   ;D
Another Brilliant mind ruined by education....  :p
Vesper
  • Last login:September 11, 2014, 12:47:57 am
  • Have you seen the Yellow Sign?
« Reply #4 on: October 15, 2002, 05:06:17 pm »
Tmolding.com sells the correct router bit.  I used it on my cabinet and it worked great.  (It's expensive for a router bit though, $35).
- Mike
nipsmg
  • Last login:February 15, 2026, 06:33:19 pm
  • ROONEY!! ERRGH!!
    • Arcadia
« Reply #5 on: October 15, 2002, 05:36:40 pm »
You want the 3-wing 1/16" slotting cutter bit from coastal tool:
53200  3-Wing 1/16"     $11.00
Also, if it's a hand held router.. they have these mountable router guides that you'll want to get.. it'll keep the router at a uniform distance from the wood the whole time.
--NipsMG   8)
NipsMG
