Author Topic: Does the X-Arcade keyboard passthrough work with adapters?  (Read 1028 times)
l33der
  • Last login:June 10, 2010, 08:02:48 pm
« on: January 17, 2005, 02:07:01 am »
I was thinking about a solution to the whole P360-isn't-possible-on-X-Arcade-PCB problem, and I realized that I have an I-Pac as well that I bought a long while ago before I decided to go with the X-Arcade PCB for the ease of console-hookup, and thought that maybe perhaps I could use the two together. I don't have any console adapters yet, as I wanted to test the waters with the board itself before I invested any extra money in it. If anyone has the X-Arcade PCB and a console adapter, I'd like to know if you could test and see if using the keyboard passthrough can trigger console controller commands. Thanks!
crashwg
Re: Does the X-Arcade keyboard passthrough work with adapters?
« Reply #1 on: January 17, 2005, 03:17:27 am »
An interesting thought to say the least but I doubt it would work.  In most cases a pass-thru is just that, a pass-thru meaning that input is not realy even recognized by the x-arcades's PCB at all...
I don't want to discourage you from trying to find out for sure though.  I'm mearly stating that you should not get your hopes up.  ;)
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
l33der
« Reply #2 on: January 17, 2005, 05:00:48 am »
Yeah, that was why I didn't just assume it would work, I figured I would ask just in case. I'm also not sure how their adapters work, it may be that the adapters just interperet the keystrokes the X-Arcade puts out, for all I know.
