Author Topic: Where to buy sheets of soft flexible foam, like from a flight case?  (Read 3294 times)
Jakobud
  • Last login:December 23, 2025, 02:48:26 am
You guys know what a 'flight case' looks like?  You know the soft foam that is usually in them to protect things?  I am looking for that sort of foam.  I think it is called polyester foam.  Does anyone know where to buy something like that?  Online or in some retail chain?  I tried Home Depot, Michaels and Jo Anns fabrics.  Jo Anns had the closest foam but it was bright green. Yuck. I'm looking for black.  If anyone knows where I could find something like that I'd appreciate it.
jakobud
« Last Edit: October 14, 2002, 10:57:39 pm by Jakobud »
Vampyre
  • Last login:April 14, 2004, 09:19:47 am
  • Roger Roger!
Re:Where to buy sheets of soft flexible foam, like from a flight case?
« Reply #1 on: October 15, 2002, 07:55:27 am »
quick search on google came up with
http://www.efoamstore.com/
dunno if its what you are looking for tho.
MameFan
« Reply #2 on: October 15, 2002, 10:15:33 am »
You are looking for what's commonly referred to as "Foam Rubber".  No, there's no rubber in it, but it stretches and compressess like rubber and returns to it's default shape, and is full of air holes, thus the name, Foam Rubber.  Usually available in cream or charcoal colors.
You will need to look for "Upholstry" stores.  You know.. the kind of stores that sell all the stuff for you to redo furniture.  Foam rubber is commonly used in chair bases and backs and other things.  These stores also usally sell leather and vinyl on cloth that are used to resurface old chairs/etc..
In most areas you will usually have some time of "all around" hardware store that sells seconds and things like screws and bolts individually (or by the #)  instead of pre-packaged, and these places usally have a section dedicated to upholstry and often have stuff such as old office furniture and even boat and car seats! (Yes, in the 3 cities with 50,000 or more people within 200 miles of me, each of them has at least 2 places like this that I am aware of)
Hope this helps!
