Author Topic: Horizontal Output Transistor?  (Read 1633 times)
GuinnessGuy74
  • Last login:November 08, 2011, 11:01:43 am
« on: January 13, 2005, 02:38:17 pm »
I had (or thought I had) a bad HOT due to the following ohm meter results
Took out Q11 (HOT), and checked it with my ohms meter. Results:
B-E (+ on B): 51 Ohms
B-E (- on B): 51 Ohms
B-C (+ on B): 1.78M Ohms
B-C (- on B): Open
C-E (+ on E): 1.78M Ohms
C-E (- on E): Open
I assumed that the B-E junction was shorted, but when I ordered a replacement ( 2sd1398 ), I have the same readings as above!
Any thoughts?
Thanks,
Jim
GuinnessGuy74
Re: Horizontal Output Transistor?
« Reply #1 on: January 13, 2005, 03:46:19 pm »
I decided to do a little more investigating, as I am getting conflicting opinions regarding my ohm meter readings (some say transistor is bad, other say it is fine!).
I found out that diode 20 was shorted! I think that might be the reason for blowing the fuse.....I am going to replace it and see what happens!
Thanks again for everyones help!
Jim
