Author Topic: One Axis on Trackballs?  (Read 1295 times)
eyal8r
  • Last login:May 11, 2007, 01:14:20 am
« on: January 12, 2005, 12:40:36 am »
Hey guys-
I got IPAC2 hooked up in XP, with Analog+ running. In XP and the Mame interface, my trackballs work the mouse cursor perfectly. When I get into any trackball games, I lose an axis on both TBs...  They only work in a diagonal motion, so if I move it up, and goes top/left, and when I move it down it goes bottom/right. Like I said tho- both TBs move the mouse cursor fine in XP.  Any ideas?
And yes, enable mouse support is turned on in Mame.
D
Silver
  • Last login:December 27, 2025, 08:11:46 am
  • Cunning like the Fox.
    • Mods'n'Mods
Re: One Axis on Trackballs?
« Reply #1 on: January 12, 2005, 12:56:35 am »
Sounds like you may have both the x and y axis mapped to each axis within mame....
Check the "input" menus within mame to see what is mapped to what.
eyal8r
« Reply #2 on: January 12, 2005, 01:23:06 am »
ok- so is that in the tab menus?  If so, how do I change it to say the right thing?  Just spin the TB in the right direction?
Thanks  bud...
D
eyal8r
« Reply #3 on: January 12, 2005, 01:37:00 am »
I found it- mouse axis menu...
Now- the only other problem I'm having is that even tho it's all set right- the P2 TB is acting as the P1 TB- but then, I have to use the P1 buttons on either player.  Same thing with the spinners.  How do I tell MAME that the P2 spinner and TB are NOT P1 but really P2?
D
Hurray Banana
  • Last login:October 18, 2016, 02:11:08 pm
  • My unique teaching style
« Reply #4 on: January 12, 2005, 04:57:09 am »
Don't you need an Opti-Pac if you're gonna connect a trackball up. If got my trackballs hooked up this way with all my other controls going into my I-Pac4. Isn't the I-Pac2 is for microswitch controls like joysticks and buttons?
Cheers Eric
TZ Pinball, PowerDrift upright, 4 vertical Mame cab and 8 way 2 player Mame cab
_Iz-
  • Last login:January 15, 2026, 06:23:28 pm
  • Time to coin up!
« Reply #5 on: January 12, 2005, 03:01:46 pm »
sounds like you have the trackball installed rotated 45
