Author Topic: Vantage flip screen support for Cocktail Cabs?  (Read 956 times)
chablis97
  • Last login:August 17, 2005, 04:30:02 am
« on: January 11, 2005, 04:22:03 am »
Does anyone know if it is possible to set up the Vantage Emulator for use on Cocktail cabinets, so the screen automatically flips 180 degrees between players 1 and 2?
chablis97
Re: Vantage flip screen support for Cocktail Cabs?
« Reply #1 on: January 11, 2005, 04:50:45 am »
Did it.  Its not documented anywhere I can find, but if you enter the on Screen Menu during play, you can set it up in 'dip switch settings', and it saves this setting for next time.
SirPeale
  • Green Mountain Man
  • Trade Count: (+23)
« Reply #2 on: January 11, 2005, 07:58:18 am »
Since these are the same games as in Mame, they will behave the same way.  If a game supports cocktail flipping with a DIP switch setting, you'd do it the same way you'd do it in Mame.
chablis97
« Reply #3 on: January 14, 2005, 04:01:26 am »
Does anyone know if the dip switch settings can be saved somehow?, so on next power up all settings are retained.
Vantage doesn't seem to keep the dip switch settings for Cocktail mode following a power down and up, or maybe its Newbie ignorance again.
