Author Topic: MameWah Install problem, please help if you can  (Read 2040 times)
bsoder52
  • Last login:June 24, 2025, 11:29:40 pm
« on: January 10, 2005, 09:51:14 pm »
I've used MameWah before in my cab, but recently had to reformat my hard drive and reload windows because I'm a dumb ass.
I installed the newest system files and the latest version of DirectX off MinWah's website, then installed the newest version of MameWah.
When I attempt to run MameWah I get the prompt:
"Runtime Error 339"
"component MSCOMM32.OCX or one of its dependencies not correct registered: a file is missing or invalid"
Thanks in advance for the help!
Bsoder52
IMMark
  • Last login:August 05, 2016, 07:30:02 pm
Re: MameWah Install problem, please help if you can
« Reply #1 on: January 10, 2005, 10:24:52 pm »
As far as the MSCOMM32.OCX, if in fact the file is missing, it is available and part of the "download system files"
http://mamewah.mameworld.net/downloads.html
not sure about the Runtime error?
« Reply #2 on: January 11, 2005, 07:03:12 am »
Try installing the system files again, and it no joy then do:
Start > Run > regsvr32 mscomm32.ocx
bsoder52
« Reply #3 on: January 11, 2005, 02:33:45 pm »
Ok, I'll try that tonight when I get home from work.
Thanks for the advice!  I'm sure it will work as you're always right!
Thanks again,
Bsoder52
