Author Topic: Monitor Anode Help  (Read 1815 times)
e35442
  • Last login:January 10, 2005, 02:45:26 pm
Monitor Anode Help
« on: January 10, 2005, 01:16:39 am »
Hello, I am new to this forum and need some help. I did a really stupid thing and cut the anode wire when removing the pcb of my monitor. Is there an easy way to splice this wire. It is almost like a coaxial cable inside (thick rubber outside, and plastic coated thin wire inside). I am aware of the discharging procedures, but not sure how to repair this wire. Can I just use a small connector, or solder it back together?
Any help would be greatly appreciated!
Thanks,
Alan
Ken Layton
  • Guru
  • Technician
Re: Monitor Anode Help
« Reply #1 on: January 10, 2005, 01:40:46 am »
You're never supposed to cut or nick that wire, but since you're new I think we can forgive you. Remember this wire carries up to 30,000 volts but typically operates on 20,000 volts. :o
Here's how to repair it:
First clean the outside jacket of the wire thoroughly with a rag moistened with 409 or other common household cleaning agent. Now go over that same area with 99% rubbing alcohol (70% or 91% will also work but the 99% is stronger). Now strip back 1/4" of insulation where the two will be joined. Form a small loop or hook in each end and connect. Now with a pair of needle nose pliers squeeze the join tight and solder it well. Now put a big glob of clear silicone glue all the way around the join and let dry for a day. Remember to put plenty of the silicone glue around it as you are insulating for 30,000 volts.
SirPeale
  • Green Mountain Man
« Reply #2 on: January 10, 2005, 02:25:30 am »
What Ken said, but I'm just curious why you'd cut this wire when it just disconnects from the tube.
hiperco
  • Last login:January 14, 2014, 08:15:13 pm
  • Mame is Cool
« Reply #3 on: January 10, 2005, 11:41:57 am »
Having recently been a newbie myself, let me help :)
To me it wasn't obvious at first that the anode disconnects under the suction cup (or that it even was a suction cup, they get sticky over time).   Luckily I asked somebody what the deal was before proceeding :)
SirPeale
« Reply #4 on: January 10, 2005, 12:08:49 pm »
Frankly, then he shouldn't be touching the monitor this way until he understands the gist of a monitor.  Esp. the "VERY DANGEROUS" part.
hiperco
  • Mame is Cool
« Reply #5 on: January 10, 2005, 12:46:41 pm »
Agreed!
e35442
« Reply #6 on: January 10, 2005, 02:45:26 pm »
I agree as well. However, I did say it was a stupid thing, so I am not pleading ignorance here. And I am aware of the dangers involved. I just figured it would be easier to cut the wire than to try and disconnect the suction cup. Simple clip and then splice, rather than mess up something else. Like I said, not the wisest thing. But I did use rubber gloves and a heavily insulated pair of wire cutters, so I was aware of the danger. Just didn't think the wire would be insulated the way it was.
Thanks for the help and in the future I will be sure to ask if I have the slightest doubt!
Alan
