Author Topic: WG K7193 Help!  (Read 1233 times)
GuinnessGuy74
  • Last login:November 08, 2011, 11:01:43 am
WG K7193 Help!
« on: January 08, 2005, 05:10:47 pm »
Ok, power up the monitor and nothing. Check the fuses, and sure enough the 3A 250V fuse is blown. Replaced the fuse and power up........fuse blows
Any thoughts on why this is happening? Thanks for all the help and advice!
Jim
Ken Layton
  • Guru
  • Technician
Re: WG K7193 Help!
« Reply #1 on: January 08, 2005, 07:53:54 pm »
Whoa! Hold on thar. That monitor is supposed to have a 2 amp slo-blo fuse not a 3 amp.
Common causes of blown fuses on the chassis are:
Shorted horizontal output transistor
Shorted flyback transformer
Shorted capacitor C36
Either one or ALL of the above.
GuinnessGuy74
Re: WG K7193 Help!
« Reply #2 on: January 09, 2005, 12:49:11 am »
First, thanks for all the help Ken!!
Ok, so I took the chassis out and removed C36 and checked it......not shorted!
Took out Q11 (HOT), and checked it with my ohms meter. Results:
B-E (+ on B): 51 Ohms
B-E (- on B): 51 Ohms
B-C (+ on B): 1.78M Ohms
B-C (- on B): Open
C-E (+ on E): 1.78M Ohms
C-E (- on E): Open
I take it that the Base to Emitter junction is shorted, causing my fuse to blow......is this a correct analysis of the above?
Thanks again for the help!!
Jim
menace
Re: WG K7193 Help!
« Reply #3 on: January 09, 2005, 07:56:02 am »
yep i would say so--another trick ken taught me--if you suspect the flyback, remove it and temporarily power the chassis--if the fuse doesn't blow, the flyback is bad.
