Author Topic: How do you setup CPViewer with MAMEwah 1.52??  (Read 1738 times)
arcadecab
  • Last login:September 26, 2007, 06:17:06 pm
« on: January 06, 2005, 09:27:55 pm »
I had CPviewer working really well with MAMEwah 0.97, but after the big upgrade, there is no longer a specific CPviewer line to direct to the .exe.  How exactly do you add CPviewer to the new versions of MAMEwah?  Anyone?
Thanks.
Re: How do you setup CPViewer with MAMEwah 1.52??
« Reply #1 on: January 07, 2005, 06:05:49 am »
app_1_executable                 c:\cpviewer\cpviewer.exe
app_1_commandline_format [name] -clone [cloneof]
Then use the LAUNCH_APP_1 shortcut to launch it, and/or set auto_launch_apps 1.
WindyM
  • Last login:September 27, 2005, 02:06:32 pm
« Reply #2 on: January 10, 2005, 09:42:34 am »
Could you expand on this. Which file, and which section - thanks.
I've just started to try to get CP Viewer working. I beleive I have the CP Viewer side configured correctly, but get stuck at the bit where it says - now configure your front end to launch CPViewer (MameWah in my case).
jcrouse
    • CPViewer
« Reply #3 on: January 10, 2005, 09:51:39 am »
In the ini folder, in your mame.ini file it should look like this:
### External Application Settings ###
ipc_file_or_path
app_2_executable
app_2_commandline_format
app_3_executable
app_3_commandline_format
auto_launch_apps
You can have a look at all my emulator ini files by using the link on my downloads page at http://home.comcast.net/~cpviewer
Good Luck,
John
