Author Topic: I made a stupid MAMEWAH mistake...HELP...  (Read 1424 times)
MAME nut
  • Last login:March 18, 2024, 12:33:01 am
« on: January 05, 2005, 05:10:10 pm »
I made a stupid mistake.
Minwah
    • MAMEWAH
Re: I made a stupid MAMEWAH mistake...HELP...
« Reply #1 on: January 05, 2005, 05:16:25 pm »
Your skin should still be in the \layouts folder...unless the installer deleted whatever was present in there...your \ini\mame.ini etc. have probably been overwritten by the stock ones  :-\
Sounds like you have some re-configuring to do...I'd recommend you grab the latest beta from the ArcadeOS/MAMEWAH board @ MameWorld.  It is stable and you would have to reconfigure to some extent anyway if you decided to upgrade later.
Delete the \files folder to get rid of lists.
MAME nut
« Reply #2 on: January 06, 2005, 09:32:53 am »
THANKS MINWAH!!
I worked for about 4 hours last night.
ras2a
  • Last login:November 19, 2016, 02:21:26 pm
  • I drink, therefore I am!
    • Nolij
« Reply #3 on: January 06, 2005, 10:04:06 am »
I made a backup of my install directory as soon as everything was cofigured (just in case).  Of course it's easy to say that now.  I've not tried configuring custom lists/favs yet, so more fun to come!  In addition to adding more emulators!
Minwah
    • MAMEWAH
« Reply #4 on: January 06, 2005, 10:20:35 am »
MAME nut: post your \ini\mame.ini and I'll see if I can see whats wrong...
MAME nut
« Reply #5 on: January 06, 2005, 07:58:28 pm »
MINWAH.....Here it is.....
### mame.ini (mamewah v1.60) ###
emulator_title                            M.A.M.E.
### List Generation Settings ###
rom_path                                  c:\mame\roms
rom_extension                             zip
dat_file
nms_file
catver_ini_file
list_generation_method                    verifysets_vs_listxml
### Execution Settings ###
emulator_executable                       c:\mame\mame.exe
commandline_format                        [name]{autodosbox}{nosafelaunch}
alt_commandline_format_1                  [name]{autodosbox}{nosafelaunch}
alt_commandline_format_2                  [name]{autodosbox}{nosafelaunch}
mouse_cursor                              none
### Artwork Locations ###
artwork_1_image_path
artwork_2_image_path                      c:\mame\marquees
artwork_3_image_path                      c:\mame\snap
artwork_4_image_path
artwork_5_image_path
artwork_6_image_path
artwork_7_image_path
artwork_8_image_path
artwork_9_image_path
artwork_10_image_path
movie_preview_path
movie_artwork_no                          1
### Screen-Saver Settings ###
enable_music_in_screensaver               1
saver_type                                slideshow
movie_path
movie_fullscreen                          1
quit_delay                                30
wrapper_executable
wrapper_commandline_format                [name]{nodosbox}{nosafelaunch}
scr_file
### External Application Settings ###
ipc_file_or_path
app_1_executable
app_1_commandline_format
app_2_executable
app_2_commandline_format
app_3_executable
app_3_commandline_format
auto_launch_apps
### Additional Settings ###
music_path
play_music_during_emulation               0
lcd_display_file_path
lcd_fe_text
### Settings used by MAMEWAH ###
current_list                              0
Minwah
    • MAMEWAH
« Reply #6 on: January 07, 2005, 06:01:03 am »
Try:
commandline_format                        [name]{autodosbox}{safelaunch}
Someone else had trouble with {nosafelaunch} IIRC.
MAME nut
« Reply #7 on: January 10, 2005, 10:11:24 am »
THANKS !!!
PROBLEM SOLVED !!!
