Author Topic: Video amp IC?  (Read 2330 times)
hiperco
  • Last login:January 14, 2014, 08:15:13 pm
  • Mame is Cool
Video amp IC?
« on: January 03, 2005, 04:55:41 pm »
I'm contemplating building myself a video amp.   Does anyone know which IC the Ultimarc video amp board uses?  TIA!
DarkKobold
  • Last login:June 18, 2013, 11:31:23 pm
Re: Video amp IC?
« Reply #1 on: January 03, 2005, 05:02:37 pm »
Have you ever built an op amp circuit before? It is a lot more difficult than it sounds. You have to select resistors and capacitors for the correct gain, while maintaining the clarity of the signal. The chip doesn't matter as much, except to audiophiles.
The best bet would be to lookup the CMOY pocket amplifier. You then have to change the diagrams to be a five channel amp. (R, G, B, H sync V sync) The best chip would probably be a dual channel op amp from TI, they give free samples to "students".
I think the gain is around 5, but don't take my word for it. I am too afraid to do my own, and I'm an EE. For 15 bucks, I think it is worth the lack of effort. You will spend at least 10 in parts (bread board, resistors, sockets, wires, capacitors) Besides, sending too much voltage could cause massive monitor damage.
My games: Tapper, Asteroids, Cocktail-MAME, Tron, ROTJ, Tempest, Star Wars (not working)
My wants: Warlords Cocktail
Grauwulf
  • Last login:July 27, 2009, 03:42:44 pm
  • Button Masher
Re: Video amp IC?
« Reply #2 on: January 03, 2005, 06:11:55 pm »
There is a pretty simple video amp circuit on the pc2jamma page.
http://www.mameworld.net/pc2jamma/hardware.html
I have this built and sitting on my bench, but I haven't had time to try it out yet.
www.wolfelectronics.ca
Cap Kits for Canadians!
hiperco
  • Mame is Cool
Re: Video amp IC?
« Reply #3 on: January 03, 2005, 06:56:13 pm »
Thanks for the replies so far.
I've built a few op amp circuits in my day (they are pretty much hard to avoid when getting an advanced degree in Electrical Engineering  ;D )
Something like the OPA3692 from TI looks interesting, (no resistors to add that might pick up noise etc), but only has a fixed gain of 2.  http://focus.ti.com/lit/ds/symlink/opa3692.pdf.  I'm wondering if something similiar (but with higher gain) is what is used on Ultimarc's version...
I've looked at the pc2jamma one,  but I was too lazy (so far) to figure out how it works without converting the layout shown to a schematic.   I'm curious to know how it works out for you, or, if you'd like to send it to me I'll be glad to check it out  ;)
I don't think amplifying the sync signals is necessary, but I'll admit that RGB video wasn't a heavily covered topic in engineering school :)
hiperco
  • Mame is Cool
Re: Video amp IC?
« Reply #4 on: January 03, 2005, 08:34:10 pm »
OK, I didn't realize that there is a hi-res picture of the amp on the Ultimarc web site.   Upon closer inspection, it looks like a "standard" op-amp with external resistors is used (I'm sure its not a garden variety type, probably a medium/high speed device for fast transitions).  I'll keep looking for an IC with a fixed gain of, say, 4.  Let me know if anyone finds something interesting :)
ericball
  • Last login:March 13, 2025, 11:01:47 am
Re: Video amp IC?
« Reply #5 on: January 03, 2005, 09:28:24 pm »
Don't forget that you need over 6 MHz of bandwidth for video.  Some op-amps have internal low-pass filters to limit destructive oscillation in typical feedback circuits.
MAME Projects % completed:
2004 3 sided cocktail cabinet w/ modular CP <25% (discarded)
2004 Tempest cabinet & CP > 75% (sold)
2017 Raspberry Pi Zero W w/ Lakka microconsole 50%
2021 Vertical Bartop - in progress > 80%, 100% functional (sleeping)
dabone
  • Last login:July 15, 2025, 08:32:17 pm
  • Time to work...
Re: Video amp IC?
« Reply #6 on: January 03, 2005, 10:13:39 pm »
I built the one on the pc2jamma page and it worked well, but not worth the trouble because of the price difference between it's parts and labor needed to assemble vs the ultimarc amp.
Later,
dabone
fredster
  • It's all good!
Re: Video amp IC?
« Reply #7 on: January 04, 2005, 12:29:23 am »
How about something old? Like a TL082c on those old Atari boards.  They cost about $1.
DarkKobold
Re: Video amp IC?
« Reply #8 on: January 04, 2005, 02:12:01 am »
hiperco
  • Mame is Cool
Re: Video amp IC?
« Reply #9 on: January 04, 2005, 11:57:08 am »
DOH! ;) You coulda said this before my EE banter, so I wouldn't have come off like an I'm an EE and you are not! >:( :D You have to admit that Op amps were one of the more difficult areas of EE.
How far did you go? I'm in my masters now, but in signal processing.
MSEE  :)
(No offense taken, by the way, your words of caution are always appropriate. The "textbook" use of op-amps is easy, its the "real life" part that will get you every time (stability, noise, etc)  ;D )
« Last Edit: January 04, 2005, 11:58:58 am by hiperco »
