Author Topic: How to adjust refresh rates to low res modes?  (Read 1284 times)
Gradius
  • Last login:February 04, 2008, 03:10:49 pm
« on: January 02, 2005, 07:35:18 am »
Are you able to tweak low res modes to control refresh rate, size and position of the display, etc... with low res modes under windows, using the ArcadeVGA? I tried with Powerstrip, but it sais it's unable to handle those modes. Any alternative?
wpcmame
  • Last login:February 18, 2024, 01:27:00 pm
Re: How to adjust refresh rates to low res modes?
« Reply #1 on: January 02, 2005, 09:17:49 am »
>Any alternative?
Use modes with doubled horizotal and vertical resolution.
lucindrea
  • Last login:July 28, 2005, 10:06:19 am
  • I dont think I'm a llama!
« Reply #2 on: January 02, 2005, 04:24:45 pm »
you can also run dxdiag and on the last tab ( options i think ) you can ovveride the refresh for all modes ... i think nvidias control panel MAY overwrite that though.
« Reply #3 on: January 04, 2005, 12:44:39 am »
common sense alert.....  I don't think nvidias control panel will be a problem considering the arcadevga is an ati card.  ;)
lucindrea
« Reply #4 on: January 05, 2005, 06:07:32 pm »
ok shows my knowlage .. thought arcadevga was software ...l either way the point is the same .. ATI's software may override the directx settings
