Author Topic: Help needed removing Happ Illuminated button from CP  (Read 950 times)
quarterback
« on: January 01, 2005, 02:04:08 am »
I've got a "Main Event" cab that has some big 'ol illuminated buttons on it and I can't get them out.
-- Chad Tower
quarterback
Re: Help needed removing Happ Illuminated button from CP
« Reply #1 on: January 01, 2005, 02:27:10 am »
Well, the answer was "use the pliers".  The button I was working on wouldn't budge, so I decided to try one of the other ones using the twist back-and-forth method and it worked fine, popping out in my hands without much trouble at all.
The first one was still stuck though, so I ended up unscrewing the nut up against the light assembly and cranked on it until the pressure popped the bulb-assembly right out.
-- Chad Tower
