March 06, 2026, 09:17:03 pm
You need to adjust the "sensitivity" values in the main config file (the name of which escapes me - check all the .ini files and you'll find it). From memory these are set to 100ms. I set mind to 250ms which stops the double-jump you talk about.
MAMEWah is still the best cab FE period.
