Author Topic: How do you set up Gens and VirtuaNES?  (Read 2071 times)
the3eyedblindman
  • Last login:November 17, 2006, 03:00:06 pm
  • Soon: 4 Player Mame and Scratch Built Moonwalker.
« on: December 27, 2004, 02:16:01 am »
I am looking to put both these emulators into my cab, but it doesnt seem to be anything like mame32, can someone please help me out on getting my rom sets for genesis and nes working with these emulators? Im just looking for specific directions on where to go ect., im very lost.
Coming soon: 4 player mame cab and Scratch built Moonwalker....Hall of Fame, here I come!
mms332
  • Last login:October 13, 2006, 01:42:02 am
Re: How do you set up Gens and VirtuaNES?
« Reply #1 on: December 27, 2004, 03:02:41 am »
Screenshotarchive.com had a page with special versions of GENS and VirtuaNES that added the ability to exit these emus with the press of the ESC key. The website seems to be closed for the moment but maybe someone else can help you there.
Another alternative is to use a command wrapper. It's a utility program that works as a shell between the front end and the emulator. It works much like a DOS Box in window but with one exception: it will monitor your keyboard for the pressing of the ESC key (or equivalent) and will shut down the application for you, returning you to the front end. Command wrappers use a configuration text file that tells it the name of the emulator and what key to use as the exit key, among other things. There are a few command wrappers around. Do a search on this forum for "comand wrapper" and you will find more information on the subject.
the3eyedblindman
« Reply #2 on: December 27, 2004, 10:54:17 am »
Thanks for that info, but right now my main concern is just getting the roms to work in these emulators. In mame32 its just "extract the files to the roms folder" and you are good to go, can anyone give me instructuons on how to set up these emulators?
RacerX
  • Last login:April 25, 2024, 04:53:33 pm
  • Longtime member, sometime poster.
« Reply #3 on: December 27, 2004, 11:30:46 am »
I don't recall there being any setup to those.  You just run them and open your ROM using the File menu.
Are you having a particular problem with them?
