Author Topic: Illustrator, colours & printing  (Read 2211 times)
« on: December 21, 2004, 07:45:06 am »
I'm working on some stuff in Illustrator for my control panel etc... My artwork is totally custom so I have a free reign on everything really.
I was wondering, since I will be getting this stuff printed properly (not sure where yet), should I be working in CMYK?  I presume this should reduce the risk of things looking different once printed.
Also, should I use / avoid certain colours?  I seen people using 'pantone' colours, but I don't really know what it means or if I should worry about it...
Any advice would be great :)
Oh, here's a CPO I started work on today.  It's loosely based on the Pole Position artwork, since I have a Pole Pos. wheel & similar looking shifter.  Thanks to tbombaci for the vectorised Pole Pos. original - I pinched the 'Atari Racing' badge.
mahuti
Re: Illustrator, colours & printing
« Reply #1 on: December 21, 2004, 10:14:51 am »
1. Should you be working in CMYK. Well if you DO work in CMYK there is less chance that you will pick a color that can not be reproduced by a printing machine. If you work in RGB, there are a number of colors that fall outside of the normal printing gamut, and will not reproduce accurately, no matter what. So that's a "yes, it sure won't hurt."
2. The "Pantone System" available as digital color swatches on computers is a totally discredited matching system, having little or no use. They do sell swatch books, which can be  useful if a client wants an exact color... the printer can use the swatch to visually match and adjust for specific colors. Using pantone digital colors will not help explain to the printer what your colors should look like, since even the Pantone swatch books do not match each other. I talked with an ex-Pantone rep once about their "system"... just chilling, how bad it is. So don't worry about using them.
One thing to note about working in CMYK, if you want a really good, dark black you might want to use "rich black" which combines K with C, M, and Y. You can search on the web for the intensities to use (something like K=100, C=50, M=20, C=20) Everybody has their own version of rich black that they swear by. It definitely WILL make your black VERY black. When you send it to a printer, you might want to tell them to use rich black for all black areas (sometimes their seperation / preflight machines will strip it out)
Also, be careful on using rich blues and deep purple colors. Those are the most likely candidates for getting messed up during printing. Mamemarquees seems to be able to reproduce them fairly well, owing to their use of a high-quality inkjet, rather than traditional printing methods. Also, be careful about small point sizes on type knocked out of a black or dark background. Again, if you used Mamemarquees, I don't think it would be a big problem.
« Reply #2 on: December 21, 2004, 01:11:36 pm »
Thanks mahuti, very helpful :)
PoDunkMoFo
  • Last login:January 09, 2025, 07:20:35 pm
  • If we weren't all crazy we would go insane... JB
    • Visual Horizons
« Reply #3 on: February 12, 2005, 02:45:53 am »
Hello,
CMYK would be the choice if you know your work will be output on a CMYK machine (4 color Cyan, Magenta, Yellow, & Black).   Most large format inkjet machines are using 6 or 8 colors which greatly expands the color gamut (or possible range of colors).  If you send a CMYK image to a machine capable of a larger gamut you are limiting your output.  Talk to the person who will be producing your work before you start designing it see what they would like.  When get raster artwork from customers I ask for RGB.
Just my 2 cents.
acejas
  • Last login:June 20, 2021, 06:15:55 pm
« Reply #4 on: February 12, 2005, 07:36:51 am »
After many years working in a traditional printing presses and then moving to wide format image printing...I have learned they are very different. After experimenting with CMYK and RGB and printing output I have found that I get a better result sticking to RGB and getting a great result.
Anywya both guys are correct in what they are saying. Just make sure you talk to teh person printing
HIH
Cheers
