Author Topic: Just A Quickie  (Read 996 times)
sasuke_kun12
  • Last login:March 10, 2009, 09:05:13 pm
  • Its been to long... I'm never leaving this place!
Just A Quickie
« on: December 20, 2004, 05:07:52 am »
what could i fit in a minimame as a marque?
fluro tube or a light globe?
Why are all the good, cheap lowboys in brisbane?
Bones
  • [Moderator]
Re: Just A Quickie
« Reply #1 on: December 20, 2004, 05:23:51 am »
Fluro light is more even. I am sure there is a better word for this type of light.....   ???
You can get small fluro's! Try a lighting company or even a pet store that sells it ready to go to suit a 1 foot tank. You may have to fiddle a bit with the shroud, but I don't see why it couldn't work.
Light globes also produce more heat which is not wanted.
SteveJ34
  • Trade Count: (+9)
  • Last login:January 06, 2024, 12:29:40 am
Re: Just A Quickie
« Reply #2 on: December 20, 2004, 08:18:05 am »
For a couple of bartop projects that are using a 10" VGA  and the width of the cabinets being only 12", I went searching for something to use to light the marquee area needing to be 12" or less.
I found a 6" fluorescent "GE Closet Light" fixture at Walmart for about $5. It is designed to operate off of batteries. I opened it up and soldered a couple of wire leads onto the battery terminals.
I was going to use a 6V wall wart AC/DC adapter but found it operates just fine and just as bright hooked up to a 5V lead from the power supply.
Something to consider....
