Author Topic: Mamewah and ArcadeVGA Vertical Hold  (Read 1500 times)
nussmier
  • Last login:November 06, 2018, 08:03:23 pm
« on: December 14, 2004, 10:12:59 am »
Hi!
I have just set up a 25" samsung monitor(cant remember model) on windows XP using maewah as my front end and ArcadeVGA.  Everything went really well.  I was able to load windows and do whatever.  As soon as I tried to run mamewah the vertical hold was off.  I adjusted it to stop it from rolling.  When I started a mame game the vertical hold was off again.  Basically I cant get the vertical hold to stop rolling.  If I fix it within a game it rolls in mamewah or if I fix it in mamewah it rolls in a game.  Do I need to more finely adjust the vertical hold or do I need the resolution software from mamewah or Ultimarc?  What is the difference between the ultimarc resolution tool and the mamewah resolution tool.  Thanks in advance for any help...
Re: Mamewah and ArcadeVGA Vertical Hold
« Reply #1 on: December 14, 2004, 12:12:23 pm »
You need to fine-tune the v-hold in *every* mode you use.  Note this could mean spending a long time making *very* minute adjustments.  If your monitor is old it might not be possible to find the sweet spot without cleaning (or replacing) the v-hold pot.
The difference between the progs you mention is basically that mine is more 'visual', and offers  greater user-fine-tuning possibilities.  If that makes any difference to you!
nussmier
« Reply #2 on: December 14, 2004, 01:26:41 pm »
Thanks.  It is a new monitor so I shouldnt have to much problem with the V hold pot.  When you say every mode what do you mean? resolution?
