Author Topic: Dave's Simple 49-way Joystick Controller  (Read 1373 times)
Rocky
  • Last login:December 30, 2009, 12:38:41 pm
  • I want to finish my cab before I retire!!
« on: December 11, 2004, 02:16:54 pm »
Well, after reading the discussion about interfacing 49-way joysticks with a PC (and saving up some cash
Tiger-Heli
    • Tiger-Heli
Re: Dave's Simple 49-way Joystick Controller
« Reply #1 on: December 11, 2004, 02:48:55 pm »
Double-sided foam tape, or maybe the clear plastic things they use to hang mirrors.
NoOne=NBA=
« Reply #2 on: December 11, 2004, 04:33:09 pm »
I haven't received mine yet, but my plan is to mount it inside a project box, so that I can put cable restrictors on it.
That's what I did with my I-pac, and my Oscar Mouse Hack.
Minwah
    • MAMEWAH
« Reply #3 on: December 12, 2004, 10:44:28 am »
I've just used double-sided stick pads atm...but I know I will be taking the panel apart to remake so I am not yet sure what I will do for the 'finshed article'...
Lilwolf
« Reply #4 on: December 13, 2004, 08:20:44 am »
I mounted mine inside a small plastic box (like a rental vcr box).  then screwed this to the underside of the control panel.
I broke a mouse hack because I didn't have it properly protected... Sucks...
