Author Topic: Anybody in MN...  (Read 1814 times)
J_K_M_A_N
Anybody in MN...
« on: December 09, 2004, 03:51:41 pm »
That is GOOD at soldering? I SUCK! I got my X3 chip but I am not doing well putting it in. I am on the pin header and it says that is the EASIEST part and I cannot get it. I am in Burnsville if anyone is close by.  :-\
J_K_M_A_N
nipsmg
  • Last login:January 20, 2026, 10:46:56 am
  • ROONEY!! ERRGH!!
    • Arcadia
Re: Anybody in MN...
« Reply #1 on: December 09, 2004, 08:37:51 pm »
If you don't have a 1.6 xbox, why not spend the 20 and get the xapt3r solderless solution?
J_K_M_A_N
« Reply #2 on: December 09, 2004, 11:06:02 pm »
I got some pointers from the guys at xbox-scene.com and I got a soldering iron with a smaller tip and everything worked GREAT! After I cleaned off the old solder and used the new iron, it went VERY smooth. I now have a modded xbox with an X3 and a 160gig hard drive. Thanks.
J_K_M_A_N
crashwg
« Reply #3 on: December 10, 2004, 12:53:26 am »
Were the pointers in a thread?  If so, could ya point me to it as I should be getting my Xenium Ice in a couple days...  :D
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
J_K_M_A_N
« Reply #4 on: December 10, 2004, 11:14:14 am »
http://forums.xbox-scene.com/index.php?showtopic=320677
There is the question I asked. I think the main things are a small soldering iron tip and make sure it is a 15W. Also remember that you can put the tip on the motherboard for a few seconds to get the pin and base heated. That is what I was afraid of. I didn't want to get the tip too close and the solder wouldn't flow to the pin and base. Good luck.
J_K_M_A_N
