Author Topic: 360  (Read 1331 times)
dave 1945
  • Last login:June 24, 2005, 02:00:50 am
  • A What!
    • The Snail
360
« on: December 06, 2004, 02:16:09 pm »
OK this has probably be asked by allot of newbies but i feel in love p360s along time ago, at the mo im making a control panel. I what it to last me a long time and have the best controls as I'll be taking it to school for our LAN party's (and play some retro games) i now where to get the 5 volts from (I'm using an ipac) but first i need to know where ground it to and second will the  ipac take the strain (i will most probably use the usb type)
Thanks for listening to me ramble  :D
dave 1945
  • A What!
    • The Snail
Re: 360
« Reply #1 on: December 06, 2004, 02:45:21 pm »
is this what it would look like
swithch gnd and volts around
« Last Edit: December 06, 2004, 02:48:58 pm by dave 1945 »
NoOne=NBA=
Re: 360
« Reply #2 on: December 06, 2004, 06:24:15 pm »
Since nobody else is answering this, I'd suggest you contact Andy at Ultimarc.
He'd be the one to know for sure how much power the I-pac can supply.
If I were doing the project myself, I'd play it safe, and pull the power directly from the computer's power supply.
You could build a nice disconnect in one of your PCI covers that would allow you to unhook the power cable without getting inside the computer case.
paigeoliver
  • Awesome face!
Re: 360
« Reply #3 on: December 06, 2004, 11:57:20 pm »
I have two of those suckers hooked up to a the +5 on a keywhiz and it is fine. It isn't the ENCODER providing the +5 anyway, the +5 on the encoder is just a direct line to the +5 from the keyboard port.
rdagger
Re: 360
« Reply #4 on: December 07, 2004, 12:22:33 am »
I'm running 3 P360's, 3 volcano buttons and a rotary interface off of a single IPAC with no problems.   However, my USB IPAC is plugged  into a self-powered hub that can easily support 7 devices drawing the maximum allowed amount of power defined by USB specification.    I wouldn't worry about the IPAC.  I'd be more concerned about damaging the motherboard if you hook up too many items on a single port.
Also the P360 pins are high at rest and go to ground when the stick is moved.  Therefore, if you use a different power source you need to make sure that it shares a common ground with the encoder and that the voltage is matched.
