October 25, 2025, 12:24:13 am
Home
Help
Search
Login
Register
News:
Support this site
Shop
Amazon
through our link. Thank you!
Well, that was weird. Outage sorted out. Thank you SirWoogie for saving the day!
Main
Monitor/Video Forum
W/G monitor problem
Main
Restorations
Software
Audio/Jukebox/MP3
Everything Else
Buy/Sell/Trade
Project Announcements
Monitor/Video
GroovyMAME
Merit/JVL Touchscreen
Meet Up
Retail Vendors
Driving & Racing
Woodworking
Software Support Forums
Consoles
Project Arcade
Reviews
Automated Projects
Artwork
Frontend Support Forums
Pinball
Forum Discussion
Old Boards
Raspberry Pi & Dev Board
controls.dat
Linux
Miscellaneous Arcade
Wiki Discussion
Old Archives
Lightguns
Arcade1Up
Try the site in https mode
Site News
Unread posts
New Replies
Recent posts
Rules
Chatroom
Wiki
File Repository
RSS
Submit news
« previous
next »
Send this topic
Print
Pages: [
1
Go Down
Author
Topic: W/G monitor problem (Read 2553 times)
68ragtop
Trade Count:
0
Jr. Member
Offline
Last login:September 21, 2007, 09:27:42 am
I want to build my own arcade controls!
W/G monitor problem
on:
December 05, 2004, 12:38:52 pm »
Hello,
Last Edit: December 05, 2004, 12:42:19 pm by 68ragtop
Logged
menace
Trade Count:
+5
Full Member
Offline
Last login:November 08, 2024, 01:49:35 pm
Re: W/G monitor problem
Reply #1 on:
December 05, 2004, 12:59:33 pm »
first things first! make sure you don't keep turning it on--its burning a line into the center of your tube--yes you have a vertical deflection failure. You might wanna check for any broken joints or loose connections on the chassis before doing anything else.
On the 7191, replacing IC2 solves alot of vertical deflection problems--Ken L or monitor guru could likley tell you exactly what to do with your model (not that there too much difference i don't think).
Logged
Ken Layton
Guru
Trade Count:
+1
Full Member
Offline
Last login:October 12, 2021, 12:25:59 am
Technician
Reply #2 on:
December 05, 2004, 01:18:33 pm »
The vertical deflection IC is a common failure on these monitors. Be careful when removing the old one from the board as the copper foil traces are delicate.
Of course you may have a simple problem like the yoke conector has come unplugged or has bad solder joints.
Logged
68ragtop
Trade Count:
0
Jr. Member
Offline
Reply #3 on:
December 05, 2004, 08:36:34 pm »
Thanks for the info! Is the IC2 identified on the board or, in a service manual? I don't have a manual for the monitor.
I will order the IC & a cap kit for it as well & see what happens. Does the forum board sponsor sell these parts? I aslo need to get some T-molding & a few micro switches.
68
Logged
Ken Layton
Guru
Trade Count:
+1
Full Member
Offline
Technician
Reply #4 on:
December 06, 2004, 12:44:01 am »
Visit this site:
www.jstookey.com/arcade/WG_25k7191/
Logged
68ragtop
Trade Count:
0
Jr. Member
Offline
Reply #5 on:
December 13, 2004, 03:50:16 pm »
Well, I replaced the IC2 chip, & Also installed a cap kit while it was apart. reflowed many solder joints on the main board & CRT board.
Unfortunatly, with no luck.
Same problem is still there. Any other thoughts?
Thanks, 68
Logged
dabone
Trade Count:
0
Full Member
Offline
Last login:July 15, 2025, 08:32:17 pm
Time to work...
Reply #6 on:
December 13, 2004, 04:45:18 pm »
Taken from the trouble shooting flowchart.
You have a vertical deflection problem.
Test for +24VDC at IC3, pin 6.
If missing, R91 may be open.
Substitute IC3, IC2, Replace C50.
If you can't center the picture, replace transistor Q9.
Later,
dabone
Logged
Ken Layton
Guru
Trade Count:
+1
Full Member
Offline
Technician
Reply #7 on:
December 14, 2004, 01:35:50 am »
Capacitor C51 which is a Tantalum .68 uf @ 35 volts, may have opened up or radically changed in value which causes vertical failure. This cap is NOT included in capkitsbut is now failing often enough that it should be included. It is located directly behind the 50/60 hz trimpot.
Logged
68ragtop
Trade Count:
0
Jr. Member
Offline
Reply #8 on:
December 24, 2004, 08:59:38 am »
Thanks again guys, I hadn't been able to get back to working on the machine until today. I tested IC3 @ pin 6 and have 25.6 VDC. Should I just replace C51? I am obviously a novice at this, & really appreciate everyones help. I really enjoy working on this kind of thing. Its very rewarding when the problem is solved. In the mean time, I will check various voltages according to the service manual, & see if I can find anything out of range that way. Is there anything that could have happened to the CRT, or other components from the drop I mentioned?
Or is that not likely?
Hope everyone has a great Holiday!
68ragtop
Logged
dabone
Trade Count:
0
Full Member
Offline
Time to work...
Reply #9 on:
December 24, 2004, 09:22:21 am »
Just for fun, have you checked for continuity from the board to the yolk?
Later,
dabone
Logged
68ragtop
Trade Count:
0
Jr. Member
Offline
Reply #10 on:
December 24, 2004, 09:26:49 am »
Thanks for quick response!
I will check that next!
Logged
Ken Layton
Guru
Trade Count:
+1
Full Member
Offline
Technician
Reply #11 on:
December 24, 2004, 11:52:50 am »
It's possible there could be cracks around the solder of the yoke connector pins, but I would examine the foil side of the board very closely for cracks/breaks first. Capacitor C51 is very delicate and if it's gone open you'll lose all vertical deflection. The value of it is critical. C51 only costs around $1 retail.
Logged
Send this topic
Print
Pages: [
1
Go Up
« previous
next »
Main
Monitor/Video Forum
W/G monitor problem
