Author Topic: joystick mounting patern  (Read 1124 times)
SPARKY70
  • Last login:June 28, 2011, 04:31:26 pm
« on: December 03, 2004, 08:32:20 pm »
do all joysticks use the same layout for mounting?
in other words, if i am using joystick A, could i upgrade to joystick B without having to modify the control panel?
thanks///sparky
Kremmit
  • - AHOTW -
  • Who the heck is that?
Re: joystick mounting patern
« Reply #1 on: December 03, 2004, 10:05:17 pm »
*Most* joysticks use the same pattern.  Some don't.  All the Happ, Industrias Lorenzo, Betson and Wico sticks I've ever seen use the "standard" pattern.
If you buy used, classic, or specialty sticks, you'll get problems.  Older games had a lot of non-standard sticks.  I don't think I've ever seen a 2-way stick that fit the standard pattern.  Pac/Ms. Pac/Tron, etc. Midway sticks are non-standard.  Analog sticks are often different.
edit- removed some wrong info- sometimes I is a dummy-head!
« Last Edit: December 05, 2004, 03:01:40 am by Kremmit »
JoyMonkey
  • Voodoo Wiki Master . . .
  • Last login:June 16, 2025, 09:16:27 pm
  • Candy is Dandy but Liquor is Quicker
    • JoyMonkey.com
« Reply #2 on: December 03, 2004, 10:38:02 pm »
I've found that generally, all US and European sticks (Happ, Wico etc.) use the same mounting pattern. Japanese sticks (Sanwa etc.) use a different pattern with a smaller footprint.
pcates
  • Last login:January 05, 2011, 08:15:57 pm
« Reply #3 on: December 04, 2004, 12:08:29 am »
I have seen 2 different mounting patterns. One with a square pattern for the screws, and the second with a rectangular pattern for the screws. I have the square on my panel, and I have been trying to find a mounting plate to mount my t-stick, because it is rectangular :(
dabone
  • Last login:July 15, 2025, 08:32:17 pm
  • Time to work...
« Reply #4 on: December 04, 2004, 12:31:57 am »
The tstick plus is a very different mounting pattern than all the happs sticks.
Later,
dabone
