Author Topic: Hot Water Heater Installation  (Read 3947 times)
« on: December 03, 2004, 09:00:34 am »
As some of you may (or may not) remember, I had a leak in my hot water heater which I temporarily fixed with some JB-Weld.  I'm going to be going on vacation around Christmas, so rather than chance a new leak and a flood when I return from vacation, I am going to replace the water heater this weekend.
I am taking out the old table-top style Hotpoint water heater and replacing it with a Kenmore table-top style water heater.
Has anyone done this kind of job before?  What exactly am I going to need before I start.  I hate starting on a project and having to stop to run to the hardware store to get some part or tool.  Any help would be appreciated.  :)  Any plumbers out there?
whammoed
  • Last login:Yesterday at 12:48:37 pm
  • Crack don't smoke itself
    • NiceMite
Re: Hot Water Heater Installation
« Reply #1 on: December 03, 2004, 09:17:06 am »
depends on how it is hooked up and what kind of pipe you have.  copper, pvc, galvanized?  Some are hooked up with flexible connections others the pipes are soldered/sweated together.  Can you post a pic?
« Reply #2 on: December 03, 2004, 09:29:39 am »
I'm at school right now, so I can't post a pic at the moment.  I do remember looking at how the old one is connected.  It has copper pipes, and it looked like the pipe from the heater was connected to the pipe from the house my some kind of threaded connection.  I'll draw a lil sketch...
danny_galaga
  • Last login:Today at 06:58:09 am
    • dans cocktail lounge
« Reply #3 on: December 03, 2004, 10:07:42 am »
i feel for all you guys that have to pay for hot water! where i live its so hot that my solar hot water system keeps things toasty even though the back-up electric part of it hasn't worked for years
« Last Edit: December 03, 2004, 10:25:47 am by danny_galaga »
whammoed
    • NiceMite
« Reply #4 on: December 03, 2004, 10:42:37 am »
« Reply #5 on: December 03, 2004, 10:44:51 am »
sorry, sketch isn't cutting it for me...maybe somebody else
if not, post a pic when you get home and I will be able to tell you what to get to hook it up.
Will do...  :)
DrewKaree
  • HAH! Nice one!
    • A lifelong project
« Reply #6 on: December 05, 2004, 11:08:54 pm »
Your threads will require either teflon tape or plumber's dope.  I dunno which type you have, but those are the two things you'll prolly need.
If you have fittings you have to re-do, then you'll need copper flux and a propane torch.
I'm guessing your tank is electric, but I didn't see if you said so anywhere.  If your water heater is gas, you'll DEFNINITELY need teflon tape to wrap the threads of the gas connector.
You'll also want a crescent wrench/channel locks/pipe wrench depending on what you can lay your hands on.
Zakk
  • Last login:March 12, 2026, 07:55:02 pm
« Reply #7 on: December 06, 2004, 09:01:42 pm »
Take care, that connection looks a lot like a fuel line (gas or oil).  The only threaded connections like that around here are either gas lines or old galvanized pipe (and they haven't used that for years.  Oh and Drew is a bit off on this one, if it's a gas connection, you should probably get a professional, and it's definitely not teflon you should use on it, it's gas fitter's grease (also known as dope) .  Teflon is good for threaded water connections tho...
Post that pic and let us all get a look at it.
Mameotron
« Reply #8 on: December 06, 2004, 09:38:52 pm »
The easiest way to tell if you have a gas or electric water heater is to look for the exhaust pipe sticking out of the top.
DrewKaree
  • HAH! Nice one!
« Reply #9 on: December 06, 2004, 09:54:31 pm »
Actually, I didn't specify which type of gas, so you're both half right and I'm half of whatever's left over  :)
The galvanized pipe Zakk is talking about will be more than likely black (I can't ever recall seeing it in another color) and depending on the age of your house, it MAY be used.  My parents' house still uses it in places, but it's not for drinking supply, just outside lines.  We'll be replacing it in spring if it doesn't burst first  :-\
Zakk
« Reply #10 on: December 06, 2004, 11:28:08 pm »
DrewKaree
  • HAH! Nice one!
« Reply #11 on: December 07, 2004, 12:03:17 am »
Hey Zakk, can you find out from your buddy what he thinks pipe dope should look like?
The stuff I'm used to seeing is kinda like a play-do consistency.
If that's what your buddy describes it as, I'd like to be sure.
The reason I ask is the link you provide shows teflon paste (which they call pipe dope) and looks exactly like what my pipes look like after wrapping the threads with teflon tape.
I have a feeling your buddy is thinking pipe dope of the same kind I am.  I'd just like to be sure, is all.
Zakk
« Reply #12 on: December 07, 2004, 01:29:34 am »
Hmm, dope was a word I had in my head, he never used the term, he said compound, and said it was a thin paste that worked into the threads.  He sent me that link to show me what he was talking about.  (Grease like?)  Now mind you, he never said that it didn't contain teflon, he was just specific in that they never use the tape.
 I still think I would call an expert when it comes to gas.    :o
DrewKaree
  • HAH! Nice one!
« Reply #13 on: December 07, 2004, 01:40:09 am »
Sorry, you set me up so well, it would be CRIMINAL for me not to take the opportunity  :police:
I have gas ALL the time.  That HAS to make me an expert.   ;D
Back to important stuff.  Gotcha on the dope/paste thing.  That's all I wanted to know.
No matter what is used, it's gotta have some teflon in it.  Otherwise the threads may become chemically locked together forever, and you DON'T wanna be using a saw on a connected line if you can possibly help it (the term KABLOOEY comes to mind ;) )
Yeah, if it's gas, I'd call an expert.  My number is 414-54......sorry, couldn't resist one last bit  ;D
Zakk
« Reply #14 on: December 07, 2004, 01:56:34 am »
Ugh, with that mental image, I'll retire for the evening.  My condolences to your wife :)
 Oh, and you'd be proud of me, I went out and bought the HumVee of houses.  3000 square feet of energy wasting goodness.  Hot tub in minus 30 degree weather?  You bet I gots me one of those!   ;D
DrewKaree
  • HAH! Nice one!
« Reply #15 on: December 07, 2004, 02:43:33 am »
Funny you mention retiring for the evening.  I got a "Darwin Awards" e-mail about a guy who had feasted on cabbage and beans, and the resulting methane cloud in his airtight bedroom while he slept did him in!
Although I'm fairly sure it's untrue, it still has enough believability to it to make ya think  ;D
Please tell me you have the International Pickup truck idling in the driveway  ;)
How much of that Sq Ft is dedicated to your arcade, or did Mrs Zakk put the kibosh on that?
« Reply #16 on: December 07, 2004, 09:10:01 am »
Lol...  I had forgot about this thread.
It's an electric water heater...  that line is definately a water line (turned the hot water on, felt the pipe, pipe started heating up).  It runs on 240 volts, has two heating elements, etc...
I'll be changing it out this Thursday (help couldn't come on the weekend).
Zakk
« Reply #17 on: December 07, 2004, 02:33:24 pm »
DrewKaree
  • HAH! Nice one!
« Reply #18 on: December 07, 2004, 04:17:34 pm »
Haruman, I dunno your skills, but if that water supply pipe is not copper pipe, and if it's black in color like I mentioned before, I'd SERIOUSLY consider either paying a plumber or doing it yourself (again, I dunno your skills) and replacing any black pipe you have in your water supply.  You're simply asking for a rusty leak you won't realize until it's too late kinda headache further down the road.
IF it's black pipe (galvanized pipe).
If it's copper, no worries.
PVC would be better and an easier replacement.
Zakk, I haven't been to your site in a while, either that's a nice page or a sweet redesign of the site - in either case, sweet HumVee house!  I like the walk-out basement as well!
Zakk
« Reply #19 on: December 07, 2004, 05:10:39 pm »
Thanks!  I won't be worrying about flooding in this house, I just open the door and let the water out!  ;D
« Reply #20 on: December 07, 2004, 05:11:48 pm »
Drew...  its copper pipe.  :)  No worries.
Zakk
« Reply #21 on: December 07, 2004, 05:12:59 pm »
Don't let the Home Depot guys sell you on compression fittings then, only solder copper.  You'll save yourself a bit aof headache down the road.
Mameotron
« Reply #22 on: December 07, 2004, 09:05:10 pm »
Zakk, I'm sorry.
DrewKaree
  • HAH! Nice one!
« Reply #23 on: December 07, 2004, 11:34:55 pm »
Zakk, I'm sorry.  It looks like you are right.  I'll take the word of a gas company guy over the word of the teenagers that work at my Home Depot any day.
It's really sad, Home Depot used to be a great place to go for info as well as materials, but lately they have turned into a real circus.  With a brand new Lowe's now open and a Menard's under construction I'm hoping they shape up.
Sorry for the rant.  And I can't get that stupid Menard's commercial jingle out of my head now.
So true.  The only thing I could POSSIBLY add to your sensible comments are
More season's greetings to you all from Menards!
 :angel:
« Reply #24 on: December 09, 2004, 03:38:37 pm »
*mutters something abouth thread hijackers..."
Anyway, lol.   :police:  Finally got the new one in, wasn't too bad a job at all.  Hardest part was getting the old one out of there.  That sucker was heavy, I think the tank on it is cast iron.
What's funny is, I found an old service contract sticker on the backside of the heater.  The service contract expired in 1974!!!
That thing is older than me!@
