Author Topic: Cut Holes in Acrylic Overlay  (Read 1497 times)
eyal8r
  • Last login:May 11, 2007, 01:14:20 am
« on: December 03, 2004, 12:06:40 am »
Hey guys-
Am getting ready to cut holes in the CP. I bought some high impact acrylic at Lowes tonight ($14 OUCH!). I also bought a spade bit for the buttons and a regular hole saw for the tbs.
Question-  I'm worried about the spade bit and hole saw splitting/chipping/breaking the acrylic overlay. It says it's high impact, but it's only 0.80" thick, and I've easily split this stuff before drilling holes. I know I can tape the holes with Duct Tape and cut the holes slow, but, I'm still worried about it. Mainly worried about the Spade bit doing it- should I go back and get the hole saw instead of the spade bit?  Or, will the spade bit be ok?  Any insights?
D
GGKoul
  • Cheesecake Apprentice
  • Last login:May 26, 2024, 02:06:23 am
  • I was once a big man!! -4700 posts later...
Re: Cut Holes in Acrylic Overlay
« Reply #1 on: December 03, 2004, 12:48:30 am »
Make sure the acrylic is sercure and there's no chatter when you drill.  Also, don't push hard when drilling.
Pacific Ripper
  • Last login:May 14, 2008, 12:14:30 pm
  • Tearing it up like a rag doll.
« Reply #2 on: December 03, 2004, 01:28:26 am »
The hole saw works much better than a spade bit. The spade has a higher chance of cracking the acrylic, and with a hole saw you get a somewhat cleaner cut.
eyal8r
« Reply #3 on: December 03, 2004, 02:05:41 am »
Hmmm- that's what I was afraid of. The hole saw was more expensive, but, cheaper than buying another piece of acrylic, that's for sure!
Also- I will tape the areas before I drill, but, should I also sandwich the plastic between boards?  Run the drill in reverse as mentioned in other posts?  Or is some of this not needed?
Thanks for the input...
D
Pacific Ripper
« Reply #4 on: December 03, 2004, 02:19:58 am »
Well, I sandwiched mine between boards and I used C clamps so that the acrylic wouldn't move around so much I didn't bother running the drill in reverse. You might still get a gunky build-up of melted acrylic due to the heat caused by the friction but it's easy to clean off and much better than cracking it. By the way, some places like Tap Plastics: http://www.tapplastics.com sell acrylic for a lot cheaper. I bought mine for less than $9.
« Last Edit: December 03, 2004, 02:26:09 am by Pacific Ripper »
Xiaou2
  • Last login:Yesterday at 08:23:14 am
  • NOM NOM NOM
« Reply #5 on: December 03, 2004, 02:35:52 am »
actually, a spade bit will make a smoother hole.
eyal8r
« Reply #6 on: December 03, 2004, 02:47:15 am »
wow- this is great advice!  Maybe I'll go get that hole saw since I don't have a press or guide. I'll let you guys know when it's done. I still don't have the graphics done yet- not even started. In fact, I'm lost for ideas. I might just cheese out and take a pre-made overlay- lol... and to think I got my Master's Degree in Computer Graphics!  LOL!!!  Oh well, time is money, and this is just a fun little project, so design isn't overly important.
Thanks for all the help guys!
D
teef two
  • Last login:November 24, 2006, 08:21:45 am
  • Mmmmame
« Reply #7 on: December 03, 2004, 05:23:28 am »
I sandwiched mine between the control panel and a bit of scrap plywood. Freehand drill using a spade bit and it worked perfectly. No cracking whatsoever. If you have a steady hand you really dont need a drill press.
Test on a bit of scrap to make sure.
PedroSilva
  • Last login:August 01, 2018, 08:37:57 am
  • Grettings !
« Reply #8 on: December 03, 2004, 06:35:02 am »
Hi,
I've used a spade bit also ... I think that the holes get to be much more smother then if you use hole saw ...
How I did it:
- Drill the acrylic attached to a piece of wood, preferable with the same size of the CP / plexi (no need to sandwish it)
- Do not remove the protective cover ...
- Use high speed (2000 rpm) and drill very very slowly ... this rotation speed will heat a little bit the acrylic and then it comes out as little strips of soft rubber ... the surroundind of the holes look perfectly smooth ...
For the trackball, I used a dremel with the wall cutter bit ...
