Author Topic: 32" Bezel Where to Buy?  (Read 2080 times)
testicle187
  • Last login:January 24, 2026, 06:08:15 pm
« on: November 30, 2004, 03:49:27 pm »
I have recently built an arcade machine from scratch and have installed a 32" television for a monitor.  I cannot find anywhere that sells a bezel that could be used for this.  My width in cabinet for the bezel is 31" and the heighth is 29".   Any help would be awesome!
Tailgunner
Re: 32" Bezel Where to Buy?
« Reply #1 on: November 30, 2004, 05:29:20 pm »
I'll go out on a limb here, no one makes a bezel that big. That said, making one yourself is quite simple, and cheap as well. :)
http://forum.arcadecontrols.com/index.php?board=1%3baction=display%3bthreadid=17175
eyal8r
  • Last login:May 11, 2007, 01:14:20 am
« Reply #2 on: November 30, 2004, 06:04:29 pm »
Tailgunner
« Reply #3 on: November 30, 2004, 07:07:53 pm »
thanks, I should work that into a signature. ;)
testicle187
« Reply #4 on: November 30, 2004, 09:26:28 pm »
Sorry about posting this thread I searched around for a little while with no results except for the homemade bezel, so I guess I will have to venture that way.  Thanks a lot!
Tailgunner
« Reply #5 on: December 01, 2004, 01:12:39 am »
No harm in asking. Honestly though, the largest arcade monitor I've seen was a 27", excepting projection monitors used in the showcase cabs. Those don't use bezels, so you're pretty much stuck with making one or painting the backside of the plexiglas overlay.
