February 04, 2026, 02:41:10 pm
It depends on the joystick you are using. I found that I had to route out my CP from underneath for a J-Stik - if I didn't, it sat way too low with 3/4" plywood. I gather that other joysticks have longer shafts so this may not be a problem with them.
Quote from: captainpotato on November 29, 2004, 08:24:01 amIt depends on the joystick you are using. I found that I had to route out my CP from underneath for a J-Stik - if I didn't, it sat way too low with 3/4" plywood. I gather that other joysticks have longer shafts so this may not be a problem with them.Thats because the j-stick was designed for metal panels, not wooden panels.If you use the correct joysticks for the correct applications then you don't have to route anything.
[Thats because the j-stick was designed for metal panels, not wooden panels.If you use the correct joysticks for the correct applications then you don't have to route anything.
Firstly what is your CP made out of? Secondly it should be fine, in fact better tan 3/4 as you will get better height out of your joysticks.
