Author Topic: Connecting BNC?  (Read 1550 times)
Connecting BNC?
« on: November 24, 2004, 01:31:43 pm »
Both of my monitors have BNC connectors... I know the pinouts and such and that the best way is probably to cut the VGA cord from a dead monitor and use that... but what I don't know yet is how you attach the BNC connectors to the wires.  Is it a crimp or something else?    ???
dabone
  • Last login:July 15, 2025, 08:32:17 pm
  • Time to work...
Re: Connecting BNC?
« Reply #1 on: November 24, 2004, 01:55:02 pm »
Not worth the trouble or buying the connectors yourself.
Found these on pricewatch.
http://www.bonuscable.com/advanced_search_result.php?keywords=20601
Unless you have a few bnc connectors laying around this will be much cheaper.
Later,
dabone
Re: Connecting BNC?
« Reply #2 on: November 24, 2004, 02:00:33 pm »
Hey, very nice... too bad I can't get them for work over the Thankgiving break.   :(
How can I confirm that the pinouts are what I need?  One of the monitors is rgb and the two syncs, the other is rgb and composite.
Silver
  • Last login:December 27, 2025, 08:11:46 am
  • Cunning like the Fox.
    • Mods'n'Mods
Re: Connecting BNC?
« Reply #3 on: November 26, 2004, 07:33:10 pm »
If its listed as a VGA (15pin male) to BNC connector - I don't belive there is any issue with incorrect pinouts. ie all VGA sockets are the same in terms of which pin is RGB and H and V sync.
Re: Connecting BNC?
« Reply #4 on: November 27, 2004, 08:50:06 am »
Yeah... after taking a good look at the 50" monitor, as well as the 27", I ended up ordering a pair of VGA-> 4 BNC cables.  I had remembered the big monitor as separate syncs but it's not... we'll see how it works out.
I may end up hacking some consoles for RGB as well, so ordering more of those suckers would probably be my best bet.
