Author Topic: MAME vector game questions...  (Read 2129 times)
« on: November 22, 2004, 09:17:09 am »
I have a question... I am using MAMEWAH with command line MAME 086.  When I play on my TV using the TV out and S-Video connection, raster games look great.  However, when I try to play a vector game, the game is huge, and I only can view like the upper left quadrant of the game.  How do I correct this?
seibu
  • Last login:March 28, 2007, 12:55:34 pm
Re: MAME vector game questions...
« Reply #1 on: November 22, 2004, 09:34:48 am »
Specify a resolution on the command line. Chances are MAME is asking the OS "What's the biggest resolution I can run this vector game at?" and the OS is replying "Why, it's this super huge size", which is then run as an auto-pan mode over s-video.
« Reply #2 on: November 22, 2004, 01:37:55 pm »
ahh ok..  I just specified the resolution in an .ini file for the game.  What is the resolution of a standard TV set?
ericball
  • Last login:March 13, 2025, 11:01:47 am
« Reply #3 on: November 22, 2004, 04:31:36 pm »
640x480 is typical (NTSC)
640x240 for non-interlaced
Horizontal resolution is a function of the pixel clock & blanking ratio.  So a DVD (720x480) uses a 13.5MHz dot clock, which gives a total line of 858 pixles @ 15.7KHz.  Square pixel NTSC (640x480) has 780 pixels per line or a 12.27MHz dot clock.
Note, people who use 800x600 for TVout aren't getting any additional vertical resolution.  Composite will top out at 320/455x480 due to aliasing with colorburst frequency (3.57MHz)
MAME Projects % completed:
2004 3 sided cocktail cabinet w/ modular CP <25% (discarded)
2004 Tempest cabinet & CP > 75% (sold)
2021 Vertical Bartop - in progress > 80%, 100% functional (sleeping)
« Reply #4 on: November 22, 2004, 08:38:04 pm »
Thanks for the information.  It is proving helpful...  :)
« Reply #5 on: December 06, 2004, 01:09:37 pm »
Got another question...  my TV out won't let me output anything lower than 800x600, and it does the scrolling desktop thing.  Is there any way to force it to output a lower resolution?
It's a nvidia GeForce FX card
Minwah
    • MAMEWAH
« Reply #6 on: December 06, 2004, 01:53:29 pm »
« Reply #7 on: December 06, 2004, 04:26:35 pm »
You can also make a vector.ini which will be applied to all vector games...
ahh cool, that saves me the trouble of writing a whole bunch of .ini files.  Does it still go in the INI folder?
