Author Topic: Not really possible to have 2 players under DOS AdvanceMame ?  (Read 1064 times)
tisurame
  • Last login:August 03, 2025, 10:50:53 am
« on: November 17, 2004, 09:58:40 pm »
About the DOS version...
3.2.5 allegro - Allegro joystick (DOS)
This driver works in DOS and it uses the Allegro library.
It supports only one joystick.
Details on how to build the Parallel Port hardware interfaces for SNES, PSX, N64 and other pads are in the Allegro sources.
Is it really not possible to have 2 players using DOS AdvanceMame ?
Weird. I would like to use two SideWinder Gamepad joysticks.
« Last Edit: November 17, 2004, 09:59:23 pm by tisurame »
jerryjanis
  • Last login:February 02, 2023, 01:56:44 am
  • Skate or Die!!!
    • Jake's Joystick
Re:Not really possible to have 2 players under DOS AdvanceMame ?
« Reply #1 on: November 17, 2004, 10:53:27 pm »
You could always use a keyboard encoder instead.
