Author Topic: How many layers of primer and how many layers of paint?  (Read 1867 times)
Will
  • Last login:April 08, 2012, 03:32:27 am
  • Finished Lurking.....
« on: November 16, 2004, 03:50:14 pm »
Title says it all im in the painting stage and have done one layer of primer.Do i need to sand between every layer and how many layers is good for primer and paint?Im using latex based primer and paint.Thanks in advance...
« Last Edit: November 16, 2004, 10:57:24 pm by Will »
neuromancer
  • Last login:May 10, 2006, 04:26:57 pm
  • Can I Play?
Re:How many layers of primer and how many layers of paint?
« Reply #1 on: November 16, 2004, 04:00:05 pm »
If you have good quality paint and primer, and a well prepaired surface, and good rollers or brushes, then you can use one coat of each.
I usually opt to put one primer, and then two thin coats of paint though. I don't sand between usually.
Bob
zaphod
  • Last login:September 04, 2012, 11:11:38 am
    • ArcadeCab.com
« Reply #2 on: November 16, 2004, 04:02:39 pm »
This has been discussed a number of times in last couple months with a several alternatives described.
The way I handled it (assuming you used MDF or quality ply), is one coat of Kilz, followed by three or four coats of good quality paint, applied with a roller.  I did not sand between as I prefer the nice eggshell texture.  Let the paint dry between coats.
« Last Edit: November 16, 2004, 04:03:17 pm by zaphod »
Shape D.
  • Last login:July 05, 2012, 06:17:57 pm
  • >Look at me, I'm a Newbie<
« Reply #3 on: November 16, 2004, 04:23:29 pm »
I would recomend two coats of primer (three if your wood is porus). And two coats of paint if you don't  sand, 3 or 4 if you do sand.
Hey Baby, Have you ever met a Newbie with 38 pages of previous posts before? Do you Want to?
